Basic Stamp alarm
MacGeek117
I'm working on an alarm using the BS2. It will sense a beam of IR across a doorway
and if that beam is broken, the BS2 will emit a 4000 Hz tone for 1 second.
bugg
So many projects, so little time.
bugg
bugg
Jon Williams
Dallas, TX· USA
bugg
The Tx is a 74LS04 osillator circuit.
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
the NERD, Kelie B.
· If electricty comes from electrons, does morality come from morons?
bugg
Boe-bot: $229
Toddler: $249
bugg
Boe-bot: $229
Toddler: $249
This significantly increased the accuracy of the beam.
bugg
Boe-bot: $229
Toddler: $249
The only problem I see is all the wiring along the house making your wife go crazy!!!
If you want to increase the volume of a "raw piezo" (i.e no internal piezo circuitry), then
see my reply in the "Stamps in Class" section several months ago about amplifying a piezo speaker.
http://forums.parallax.com/showthread.php?p=464410
Beau Schwabe
IC Layout Engineer
DONT REST UNTIL YOU BEAT THE BEST
bugg
Boe-bot: $229
Toddler: $249
