Finished Talking Multimeter that uses METEX — Parallax Forums
John WhitfieldJohn Whitfield Posts: 42
edited 2005-08-07 21:42 in General Discussion
I want to thank everyone on the board that helped me finish my project. I am posting a the final code and schematic, for anyone who wishes to build their own. The delay timing could still probably be improved, but works properly most of the time.
-John Whitfield
  • James NewtonJames Newton Posts: 329
    edited 2005-08-07 19:39
    This is nice! First for anyone with a visual imparement and also as a way to not have to glance up at a readout when you are holding probes in a very tight or slippery place.
    Have you done a PCB layout of this? If anyone will do a layout, I can pretty much assure you a set of boards from the PICList.com PCB contest
    http://www.piclist.com/pcbcontest and then people can order the boards from Olimex or whereever if they want to make one.
    James Newton, Host of SXList.com
    james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
  • John WhitfieldJohn Whitfield Posts: 42
    edited 2005-08-07 19:52
    I used the express PCB software to make the schematic and then scanned it and the parts into my mac.
    Next, I used photoshop to lay everything out, and finally scaled it up so it would print out nicely. So, if anyone wants the original PCB file, here it is...
    -John Whitfield
    edited 2005-08-07 21:26
    John,
    glad to learn that you have finally finished your project.
    I sincerely hope that this project has "watered your mouth" enough to go ahead with more SX projects in your future career.
    Good Luck!
    Greetings from Germany,
    G
    G
