I want to thank everyone on the board that helped me finish my project. I am posting a the final code and schematic, for anyone who wishes to build their own. The delay timing could still probably be improved, but works properly most of the time.
-John Whitfield
Have you done a PCB layout of this? If anyone will do a layout, I can pretty much assure you a set of boards from the PICList.com PCB contest
http://www.piclist.com/pcbcontest and then people can order the boards from Olimex or whereever if they want to make one.
James Newton, Host of SXList.com
james at sxlist,com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Next, I used photoshop to lay everything out, and finally scaled it up so it would print out nicely. So, if anyone wants the original PCB file, here it is...
-John Whitfield
glad to learn that you have finally finished your project.
I sincerely hope that this project has "watered your mouth" enough to go ahead with more SX projects in your future career.
Good Luck!
Greetings from Germany,
G
