LM7805T Question
MacGeek117
My next project will need me to connect a LM7805T to a·car battery. Can the 7805 handle the voltage?
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
bugg
Boe-bot: $229
Toddler: $249
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
You would be better off with a dc/dc converter, as you are loosing a lot of power in the 7 volt drop, unless you need the heat?
Bob N9LVU
bugg
Boe-bot: $229
Toddler: $249
I have several applications using a 7805 run from a vehicle. I don't recommend stepping down to 9 volts, then 5 volts.
Ken
Post Edited (KenM) : 7/24/2005 5:48:11 AM GMT
bugg
Boe-bot: $229
Toddler: $249
Post Edited (bugg) : 7/24/2005 12:41:38 AM GMT
- use Parts List #2 for a 7805 circuit
Taking a worst case scenario of power the regulator must dissipate....
P = IE
Worst case E = 9.7· (14.7 - 5 = 9.7)
Worst case I = 0.3 Amps
9.7 * 0.3 = 2.91 watts
Ken
here is a picture of the DC/DC converter PCB I have designed. Input voltage range: 8...30 V, output voltage: 5V @ 500 mA with short circuit and over-heat protection. Just, one LM2574, a throttle coil, one Shottky diode, and two elcaps. If you like to see the schematic, just let me know...
Greetings from Germany,
G
here comes the schematic.
You can find more information about the LM2574 in www.national.com/ds.cgi/LM/LM2574.pdf.
The reason for my specific PCB design is that I needed it as replacement for the Rohm BP5220 DC/DC converter, I've been using in one of my industrial projects. Instead using a separate PCB for the converter, you could install the few components on your main PCB (this is what I'm doing in the meantime).
I like this approach because of the better efficiency (i.e. less power dissipation = heat).
G
bugg
Boe-bot: $229
Toddler: $249
