Parallel LCD help
My parallel LCD has 16 pins and i dont know how to wire any help?
Thanks in advancee,
Micro
1 + 1 = Window
0............................................0
0.(Microman171@hotmail.com)..0
Thanks in advancee,
Micro
1 + 1 = Window
Jon Williams
here is some pin names
1 = Ground (0v)
2 = Supply Voltage fo Logic (+5v)
3 = Contrast Adjustment
4 = Data / Instruction Select (RS)
5 = Read / Write Select (R/W)
6 = Signal Enable (E)
7 - 14 = Data Bus Line (DB0 - DB7)
16, 15 = No connection
And also there are thesse pins on the side that I don't know what there for (A and K)
Thankyou
Micro
PS This LCD is non-Backlit
1 + 1 = Window
Jon Williams
I'm Asking because I found some ITM 1602A from Intec , real cheap, but the seller didn't know anything about it , then I just did not buy, ( that was today in the afternoon ) I'm looking for this specs now and this looks like the same ( at least the pin numbers )
Ricardo Amaral
1 + 1 = Window
·· The datasheet on that web page you listed clearly indicates the connections for this LCD.· For simplicity you can usually connect pin 3 to Vss (Ground).· On your LCD pins 15/16 are no connection.· The rest just double-check with what you should have.· Also, remember, for 4-bit mode you'll use DB4-DB7 not the first 4 data lines (DB0-DB3).·
Chris Savage
Parallax Tech Support
csavage@parallax.com
1 + 1 = Window
1 + 1 = Window
The BASIC STAMP!
by The LCD
I think the code I have runs in 4 bit (not sure)
please send full code and how to use it thanks
Micro
1 + 1 = Window
this is the code I have
' ========================================================================= ' ' File....... SW20-EX11-LCD_Demo.BS2 ' Purpose.... Essential LCD control ' Author..... (C) 2000 - 2005, Parallax, Inc. ' E-mail..... support@parallax.com ' Started.... ' Updated.... 01 JUN 2005 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' This program demonstrates essential character LCD control. ' ' The connections for this program conform to the BS2p-family LCDCMD, ' LCDIN, and LCDOUT instructions. Use this program for the BS2, BS2e, ' or BS2sx. There is a separate program for the BS2p, BS2pe, and BS2px. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- E PIN 1 ' Enable pin RW PIN 2 ' Read/Write RS CON 3 ' Register Select LcdBus VAR OUTB ' 4-bit LCD data bus ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- LcdCls CON $01 ' clear the LCD LcdHome CON $02 ' move cursor home LcdCrsrL CON $10 ' move cursor left LcdCrsrR CON $14 ' move cursor right LcdDispL CON $18 ' shift chars left LcdDispR CON $1C ' shift chars right LcdDDRam CON $80 ' Display Data RAM control LcdCGRam CON $40 ' Character Generator RAM LcdLine1 CON $80 ' DDRAM address of line 1 LcdLine2 CON $C0 ' DDRAM address of line 2 #DEFINE LcdReady = ($STAMP >= BS2P) ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- char VAR Byte ' character sent to LCD idx VAR Byte ' loop counter ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- Msg DATA "0123456789abcdef0123456789abcdef", 0 ' store message ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: #IF (LcdReady) #THEN #ERROR "Please use BS2p version: SW20-EX11-LCD_Demo.BSP" #ENDIF DIRL = %11111110 ' setup pins for LCD PAUSE 1000 ' let the LCD settle Lcd_Setup: LcdBus = %0011 ' 8-bit mode PULSOUT E, 3 PAUSE 5 PULSOUT E, 3 PULSOUT E, 3 LcdBus = %0010 ' 4-bit mode PULSOUT E, 1 char = %00101000 GOSUB LCD_Cmd char = %00001100 ' disp on, no crsr or blink GOSUB LCD_Cmd char = %00000110 ' inc crsr, no disp shift GOSUB LCD_Cmd ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: char = LcdCls ' clear the LCD GOSUB LCD_Cmd PAUSE 500 idx = Msg ' get EE address of message Write_Message: DO READ idx, char ' get character from EE IF (char = 0) THEN EXIT ' if 0, message is complete GOSUB LCD_Out ' write the character idx = idx + 1 ' point to next character LOOP PAUSE 2000 ' wait 2 seconds Cursor_Demo: char = LcdHome ' move the cursor home GOSUB LCD_Cmd char = %00001110 ' turn the cursor on GOSUB LCD_Cmd PAUSE 500 char = LcdCrsrR FOR idx = 1 TO 15 ' move cursor l-to-r GOSUB LCD_Cmd PAUSE 150 NEXT FOR idx = 14 TO 0 ' move cursor r-to-l by char = LcdDDRam + idx ' moving to a specific GOSUB LCD_Cmd ' column PAUSE 150 NEXT char = %00001101 ' cursor off, blink on GOSUB LCD_Cmd PAUSE 2000 char = %00001100 ' blink off GOSUB LCD_Cmd Flash_Demo: FOR idx = 1 TO 10 ' flash display char = char ^ %00000100 ' toggle display bit GOSUB LCD_Cmd PAUSE 250 NEXT PAUSE 1000 Shift_Demo: FOR idx = 1 TO 16 ' shift display char = LcdDispR GOSUB LCD_Cmd PAUSE 100 NEXT PAUSE 1000 FOR idx = 1 TO 16 ' shift display back char = LcdDispL GOSUB LCD_Cmd PAUSE 100 NEXT PAUSE 1000 GOTO Main ' do it all over ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- LCD_Cmd: LOW RS ' enter command mode LCD_Out: LcdBus = char.HIGHNIB ' output high nibble PULSOUT E, 3 ' strobe the Enable line LcdBus = char.LOWNIB ' output low nibble PULSOUT E, 3 HIGH RS ' return to character mode RETURNAnd I want to know how to put a line break in this codee and where
1 + 1 = Window
Post Edited (Microman171) : 7/23/2005 11:23:30 PM GMT
