Parallel LCD help
My parallel LCD has 16 pins and i dont know how to wire any help?
Thanks in advancee,
Micro
1 + 1 = Window
0............................................0
0.(Microman171@hotmail.com)..0
Thanks in advancee,
Micro
1 + 1 = Window
Jon Williams
here is some pin names
1 = Ground (0v)
2 = Supply Voltage fo Logic (+5v)
3 = Contrast Adjustment
4 = Data / Instruction Select (RS)
5 = Read / Write Select (R/W)
6 = Signal Enable (E)
7 - 14 = Data Bus Line (DB0 - DB7)
16, 15 = No connection
And also there are thesse pins on the side that I don't know what there for (A and K)
Thankyou
Micro
PS This LCD is non-Backlit
1 + 1 = Window
Jon Williams
I'm Asking because I found some ITM 1602A from Intec , real cheap, but the seller didn't know anything about it , then I just did not buy, ( that was today in the afternoon ) I'm looking for this specs now and this looks like the same ( at least the pin numbers )
Ricardo Amaral
1 + 1 = Window
·· The datasheet on that web page you listed clearly indicates the connections for this LCD.· For simplicity you can usually connect pin 3 to Vss (Ground).· On your LCD pins 15/16 are no connection.· The rest just double-check with what you should have.· Also, remember, for 4-bit mode you'll use DB4-DB7 not the first 4 data lines (DB0-DB3).·
csavage@parallax.com
1 + 1 = Window
1 + 1 = Window
The BASIC STAMP!
by The LCD
I think the code I have runs in 4 bit (not sure)
please send full code and how to use it thanks
Micro
1 + 1 = Window
this is the code I have
And I want to know how to put a line break in this codee and where
1 + 1 = Window
Post Edited (Microman171) : 7/23/2005 11:23:30 PM GMT
