Help with BS2 and pressure sensor
Hi, I'm new to the forum so i want to say hello to everyone out there. Let me get to the question I have. I'm using the basic stamp·the BS2 (educational borad) and I'm doing some of the samples that parallax have listed in the [font=Arial,Bold]
Basic Analog and Digital [/font][font=Arial,Bold size=5]Student Guide [/font]VERSION 1.3. Right now I'm going over chapter 3 in the online book. I have the circuit setup just like they instru. But the thing is i'm removing the POT and using a sensor. The problem is that the sensor is not giving me any valves back. I was wondering if anyone as every worked with a 6 pin air pressure sensor (company name Fujikura Ltd). Te sensor send out a voltage which i'm taking that and putting it into the ADC (analog·digital converter)·083. Also the way I test the circuit was i left the POT into make sure the curcuit was hooked up correctly which it was (working fine with the POT), but soon as I replaced it with the pressure sensor I didn't get any valves that I could use. If anyone could help me I thank you so much cuz i have not been able to get it to work correctly. I attach the spec sheet of the sensor.
and again thanks
and again thanks
·· If you have both caps connected as in the datasheet and you have the 3 connections to the Stamp/ADC power and signal connections, what readings are you getting from the ADC?· Also, have you tried applying pressure through the aperture under the sensor?
Chris Savage
Parallax Tech Support
csavage@parallax.com
