SX Addressing - Non Addressable Chips — Parallax Forums
DigitalDjDigitalDj Posts: 207
edited 2005-07-25 08:44 in General Discussion
Hello,
I would like to know if it is possible to input I2C signals into a SX chips input/output pins and have the SX chip select which 8 sets of I2C outputs to output to? The reason for this is to address 8 chips at any one time that are not addressable by software or hardware on the chip itself.·I have included a drawing.
Kevin
Post Edited (DigitalDj) : 7/8/2005 12:43:03 AM GMT
    edited 2005-07-08 03:55
    Yes, its very do'able. The doc page for the SX has code for master and slave I2C. You may be able to squeeze it (# of pins) into an SX28.
    Post Edited (Paul Baker) : 7/8/2005 4:00:04 AM GMT
    edited 2005-07-08 15:06
    Kevin,
    to make things simpler, you can tie together the SCL pins of all I²C devices, and control them from one SX output pin. That is, you "only" need to use eight different SX pins to control the SDA line of each device separately. Of course, this only works as long as you communicate with just one device at a time.
    You migt use one of the different available SX sample codes for an I²C master. I would suggest to add a subroutine which is called instead of setting/clearing/high-Zing the SDA line. The subroutine then takes care of controlling the right SDA pin.
    Greetings from Germany,
    Günther
  • DigitalDjDigitalDj Posts: 207
    edited 2005-07-09 03:14
    Thanks Paul and Gunther!
    The chip i am wanting to address is the National LM4970, the more i look at the specs this chip has a address pin but the engineers at National says that it cannot be addressed as more than one chip. The address pin in the docs says it has 2 states X0 logic low and X1 logic high and is used to address a number of chips in a system, the LM4970's chip address can be changed to avoid any possible address conflicts. The way i take this is that the chip cannot be addressed as chip 1 thru 8 but can have all chips I2C lines tied together and the state of the address pins determine which chip can be addressed with I2C information!
    I have·included the link·for the chip if someone would like to enlighten me as to how this works!
    http://cache.national.com/ds/LM/LM4970.pdf
    Kevin
    edited 2005-07-09 07:27
    That chip has a single address pin, meaning two of these devices can share a bus, so youd need 2 pins for frontside i2c, and 8 pins for 4 backside i2c. Now if you want to get really clever on the backside i2c, you can use a 3:8 decoder ('138) with the outputs feeding the address pin of your chips. You would select the chip and it will have an address of 0 while all the rest will be 1. This will get your backside i2c pin count down to 5 pins (1 I2C bus, and 3 address pins)
    edited 2005-07-09 10:13
    Paul,
    Can you show me a diagram on that setup with and with out the 3:8 decoder?
    On page 8 of the pdf it has EC for externally configered is this so each chip can be selected by outside means(master processor)
    Kevin
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2005-07-09 15:20
    Instead of a HC138, you can also use a CD4052 (dual 4-to-1 analogue multiplexer)
    to switch input I2C lines to 1 of 4 output I2C lines. The total lines required would
    be 4 (SDA,SCL and 2 select lines). Just put 10kOhm pullup resistors on all
    ingoing and outgoing I2C lines. You would connect 2 of your chips to each
    outgoing I2C lines.
    http://www.ee.washington.edu/stores/DataSheets/cd4000/cd4051.pdf
    regards peter
    edited 2005-07-09 16:14
    Kevin, Ill draft all three when I return home.
    edited 2005-07-09 20:59
    Ok here they are, hopefully·they are·self explanetory, if not, ask, and Ill clarify.
    639 x 474 - 33K
    680 x 642 - 48K
    653 x 686 - 60K
    edited 2005-07-09 21:23
    Nice drawings!
    One remark, option C is not limited to the mentioned chip. You can use the same circuit
    to address 4x8 = 32 PCF8574 chips for example. (You get 4 I2C buses).
    regards peter
    edited 2005-07-09 21:41
    As mentioned before, IMO, there is no need to multiplex the SCL lines. They all could be tied together as it does not matter when SCL toggles on devices that are currently not connected to the SX SDA pin via the multiplexer.
    G
    edited 2005-07-09 22:32
    Gunther,
    that's true. So for option C, the 4052 could be replaced by a 4051 to give 8 I2c buses.
    (requires 5 lines then).
    regards peter
    edited 2005-07-10 17:33
    Thanks Paul for the drawings and thanks to everyone contributing!
    I am kind of new to these chips and to address them this way, i am also new to Sx programming!
    Paul,
    I have some questions on the drawings!
    Drawing 1
    1. The first drawing just has the address·lines coming from the SX and i would still have to tell the (8) LM4970's·address pins to·go low or high to address them?
    2. Since the LM4970's have address pins does that mean that all (8) Lm4970's can run off of the same I2C buss and then when i want to address each chip i just set the address pin of that chip?
    Drawing 2
    1. Are all (8) of the LM4970's using the same buss in this drawing?
    2.·Would i only·be able to address one chip at a time by multiplexing?
    3. If i can use the same I2C buss for all (8) LM4970's·could i just use the SX without the mulitplexing chip for addressing the address pins of the LM4970's?
    I guess if i wanted to use more LM4970's say 16 multiplexing would be the way to go!
    Drawing 3
    1. I don't understand·what's going on here with the CD4052, i need some explaination as to how this works.
    Since i want to control this circuit from the USB port of the computer will that change any of these circuit ideas. The reason i want to control this circuit from the computer is it gives me more versatility. Also can i get a circuit to convert USB to I2C like the circuit from Parallax for USB to serial?
    Sorry for all the questions!
    Thanks!
    Kevin
    edited 2005-07-10 18:13
    Figure A) There are no address lines in A, the LM4970 has a single address bit, since this can be set to either a 0 or a 1 that allows a maximum of 2 4970s per traditional I2C bus. Since you have 8 4970s to connect to, that requires 4 traditional I2C busses, this is what is being illustrated in the drawing. The address is set by tieing the address pin one of the 4970 on each bus to ground (Vss), and the other 4970's address pin to Vdd. The first one will have the address 0 and the second will have an address of 1. The addresses are fixed and do not change.
    Figure B) Yes all 4970s are tied to the same bus. The 74LS138 in B is technically a decoder, what it does is take a 3 bit value and drives 1 of 8 outputs low·according to the three bit value. The other outputs are high, meaning the 4970 tied to that output will have the address 0, and all the others have an address of 1, this way one is singled out so you can access it. Your only ever going to address one at a time anyways so this setup works. The essence of this setup is being able to set the address of 8 4970s using only 3 pins on the SX.
    Figure C) The CD4052 is a true dual-channel 4-way multiplexor, its operation is equivalent to a DP4T switch (dual pole, 4 way throw), IOW·two switches which have four postions and the two·switches are set to the same position. So these are used to switch a single I2C bus on the SX side to one of 4 I2C busses that contain the LM4970s, the addresses of the LM4970s are set the same as in Figure A.
    If you want·further explanation of what Geunther and Peter are talking about; ask, and one of us will explain.
    The USB issue is another topic, so start another thread with that question. (It is a seperate issue that is unaffected by this issue)
    Post Edited (Paul Baker) : 7/10/2005 6:23:09 PM GMT
    edited 2005-07-10 18:48
    For direct USB to I2C go here
    http://www.i2cchip.com/
    and scroll down to Host Adapter Products.
    Check out the datasheet for the BL233 chip
    and the ready to run I2C-2-PC USB adapter.
    The USB adapter offers 3 I2C buses so you still
    need a multiplexer to address all your 8 chips, but it relieves
    you of interfacing to the USB bus.
    regards peter
    edited 2005-07-10 20:06
    Is there a reason as to why only one LM4970 cannot be addressed at one time other than being multiplexed or decoded.
    What do you suggest as being the best way to go?
    If i wanted to add another 8 outputs what could i use besides the 138 or the CD4052?
    Sorry for all the questions, i am just eager to learn and want make everything for the project i am working on! I want the circuit to control color modules designed and a proto made up to go where the white pastic is.
    I have attached a picture of a Art Deco Jukebox i designed and building. I still have the button panel/hidden keyboard section to finsh up(getting close).
    Kevin
    Post Edited (DigitalDj) : 7/10/2005 9:34:26 PM GMT
    edited 2005-07-10 22:06
    The I2C bus is by definition half duplex. On a single I2C bus only one chip can be addressed
    at any time. If you want to address multiple chips simultaneously, you must have multiple
    I2C buses that are serviced simultaneously.
    You could dedicate an SX28 chip as follows:
    port A (pins ra.0 to ra.3) = serial port with TX,RX,RTS,CTS
    Use a max232 to connect to PC comport.
    This can connect to a USB to serial adapter to allow control via USB
    port B (pins rb.0 to rb.7) = 4x I2C bus
    port C (pins rc.0 to rc.7) = 4x I2C bus
    This gives you 8 independent I2C buses so you can connect 16 of your chips.
    The code for the SX chip would consist of 8 master I2C routines, plus
    a command routine that accepts commands via the serial port and dispatches
    them along the 8 I2C buses. This can be done. The whole would be command driven,
    meaning each I2C bus gets serviced when a command for that bus arrives.
    regards peter
    edited 2005-07-11 00:21
    Peter,
    Could you show me what that would look like and would that be tough to program?
    Kevin
    edited 2005-07-11 07:12
    Kevin,
    You have to consider memory use first.
    A I2C master running as Virtual Peripheral (to 'simultaneously' service the I2C buses)
    requires 8 bytes, so for 8 buses that is 64 bytes or 4 ram banks.
    Some buffering is necessary, assuming 4 bytes per bus, that is another 2 ram banks.
    That leaves 2 ram banks for the serial port and command dispatcher. So it seems
    to fit.
    Using threads to run the virtual peripheral is a must here. If you have 4 threads,
    during each interrupt only the Uart tx VP routine, Uart rx VP routine, and 2 I2C master VP
    needs to be executed. That is doable also.
    The command format you use, must allow you to select the I2C bus that you want to access.
    Basically you need 3 commands:
    B selects bus, B is followed by 0 to 7, eg. B 3
    W writes data to chip on selected bus, eg. W F4·addr data (access LM4970 pin adr to GND)
    R reads data from chip on selected bus, eg. R F6 addr (access LM4970 pin adr to 5V)
    This is not a project you program overnight.·You must do it in assembly (due to the VP routines
    and memory use). But it can be done. You might consider to do it in SX/B because that has builtin
    commands for I2C master. But then the buses are serviced sequentially and I am not sure wether
    that gives you enough memory.
    regards peter
    edited 2005-07-11 09:07
    Here is an assembly listing containing both I2C master VP and I2C slave VP, and two Uart VP's.
    You could use that as a starting point. It also uses threading, so all functons you need are present
    but you need to adapt it to your needs.
    regards peter
    edited 2005-07-11 17:21
    Peter,
    1. I take it that the SX will only require 1 I2C bus on the input and then the controlled I2Coutputs through the SX?
    2. How does the I2C buss know if there are more than 2 LM4970 on a buss if all chips are set high except the 1 that is low to be addressed?
    3. If memory is a problem how about going with option C with the CD4052 or CD4051 that paul has described?
    4. Am i correct in saying there is no provisions for the address lines to the LM4970's?
    I guess for now if it is a real problem i could always stick with individual addressing to the LM4970's, processing speed would be great enough to probably not see any difference. The other problem is i will need to learn to program the SX but i guess that's the fun of it!
    Kevin
    Peter Verkaik said...
    regards peter
    edited 2005-07-11 18:40
    1. If you want to control it from usb the input is a serial port and the outputs
    are the 8 i2c buses.
    2. You connect only 2 chips to each I2C bus. One of the chips must have it adr pin tied to GND,
    the other chip must have its adr pin tied to 5V.
    3. If you don't care about 'simultaneously' servicing the I2C bus, then you could program
    in SX/B which has builtin I2C commands. As commands are executed sequentially, all I2C buses
    can share the same memory. SX/B also has builtin commands for SERIN and SEROUT.
    4. See 2.
    regards peter
    edited 2005-07-11 21:50
    Peter,
    I must be missing something here, i thought the address pins also have to be controlled from high to low to send it information on the I2C buss! I thought that if i wanted to send information to chip one i would select it by bringing the address pin low and send the information on the I2C buss and then back high to address the next!
    In Pauls drawing C·the LM4970's share the I2C buss and just the address pins are controlled, this is where i'm getting confused!
    ·Sorry This should have been drawing B
    I'm kinda confused you might explain the how the I2C buss and the address pin on the LM4970 have to work together!
    Sorry!
    Kevin
    Post Edited (DigitalDj) : 7/12/2005 3:00:06 AM GMT
    edited 2005-07-11 23:13
    I explained earlier that only figure B changes the value on the address pin of the LM4970, this is not how they are typically used. In every other circumstance the pin is tied high or low, it does not change, so the one with the address pin tied to ground always has an address of 0, the other tied to Vdd always has an address of 1.
    Figure C does not show changing the address pins, see above for how the address pins are handled.
    Here let me nutshell the issue and maybe you'll understand more clearly. You have 8 identical I2C devices you are looking to control. Those devices permit a maximum of two of them on an I2C bus that can easily be accessed. This is because they only provide a single pin to set the address so that address is either a 0 or a 1, no other possibilities exist. Now here is the crux of the problem, you have 8 devices which only permit 2 of them on a bus. So Figure A says: well if I have 4 I2C busses then I can access 8 devices with 2 on each bus. Figure C says: well thats alot of pins to use (8 devices, 8 pins), so what if I put a switch in there so that what appears to be a single I2C bus to the SX is actually 4 I2C busses that the switch switches between, now we have 2 pins for the I2C bus and two pins to tell the switch what position to be in for a total of 4 pins.
    Now for Figure B, its probably best you forget about this one, it just seems to be confusing you, but here is another explanation. Figure B tosses the whole problem on its head, its looks at what can be done, even if the chips weren't really designed to be used that way. It says: ok forget about the number of I2C busses, what I need to be able to do is to access a particular device when I want to, thats all that matters. What if, instead of permanently setting the address of the I2C device like done·above, I make it so I can set the address of each device·during runtime.·So if I·can set the address of a device to a·0 while·simultaneously setting every other device's address to a 1, I can access that one device and my goal is accomplished.
    I hope this is becoming·clearer for you.
    Post Edited (Paul Baker) : 7/12/2005 12:02:58 AM GMT
    edited 2005-07-12 08:38
    Kevin,
    Here is a little program I wrote in SX/B.
    I can't guarantee it will work because I did not test it.
    regards peter
    edited 2005-07-13 01:38
    Thanks Peter, Paul and Gunther for all of the Input!!
    Yes i understand what is going on now!
    Also Thanks Peter for the program, if it doesn't work that's ok it still gives me a start! I'm sure i will be learning some programming for the SX and the whole circuit when done!
    Peter,
    Since the program is not setup to access all LM4970 at one time does that leave any memory for programming if i wanted to make the circuit stand alone without the computer control?
    Kevin
    edited 2005-07-13 05:22
    Kevin,
    Most of the ram is available, as is page 3 and part of page 2, so there is room
    for other tasks. Also note that port C pins and pins ra.2 and ra.3 are still
    available.
    regards peter
    edited 2005-07-18 01:38
    Peter,
    Which of the pins are the SDA and SCL on the 8 busses of the SX28?
    Kevin
    edited 2005-07-18 04:44
    In my sample program (just 4 buses) the pins are defined
    sda0 var rb.0
    scl0 var rb.1
    sda1 var rb.2
    scl1 var rb.3
    sda2 var rb.4
    scl2 var rb.5
    sda3 var rb.6
    scl3 var rb.7
    The builtin SX/B i2c command expect SDA on a even pin number, the SCL pin is then
    automatically the adjacent pin.
    regards peter
  • ForrestForrest Posts: 1,341
    edited 2005-07-18 09:15
    There's NO requirement in SX/B for SDA to be an even pin number. But SCL is automatically assigned to the next higher pin number in the same group as the SDA pin.
    edited 2005-07-18 10:30
    So it is.
    Thanks.
    regards peter
