Accellerometer slow limit
What is the slowest speed that an accelerometer can reliably measure?
I wonder if this wire is hot...
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Accelerometers measure G-Force. So it would depend on the resolution of the unit.
Some are designed to measure large G-Forces and some are designed to measure small G-Forces.
Then there is "Static G-Force", this is the constant g-force of gravity. With the unit turned down it should measure a constant 1.0 g-force, with the unit upside-down it will measure a constant -1.0 g-force.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Product web site: www.sxvm.com
"If you keep doing what you always did, you'll keep getting what you always got."
