Accellerometer slow limit — Parallax Forums
ElectronegativityElectronegativity Posts: 311
edited 2005-06-15 16:32 in General Discussion
What is the slowest speed that an accelerometer can reliably measure?
I wonder if this wire is hot...
  • steve_bsteve_b Posts: 1,563
    edited 2005-06-15 02:58
    What kind of accelerometer? Don't mean to sound silly....but the one we use at work only measures about 20 readings a second however the space shuttles uses ones that measure 20,000 times a second!
    Steve
    http://ca.geocities.com/steve.brady@rogers.com/index.html
  • BeanBean Posts: 8,129
    edited 2005-06-15 11:10
    Are you asking about "motion" speed ?
    Accelerometers measure G-Force. So it would depend on the resolution of the unit.
    Some are designed to measure large G-Forces and some are designed to measure small G-Forces.
    Then there is "Static G-Force", this is the constant g-force of gravity. With the unit turned down it should measure a constant 1.0 g-force, with the unit upside-down it will measure a constant -1.0 g-force.
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    "If you keep doing what you always did, you'll keep getting what you always got."
  • ElectronegativityElectronegativity Posts: 311
    I want to measure small oscillations like those that would take place in your fingers if you held your hand outstreached for awhile.
