Web Server
I'd be willing to buy any extra of the web-interfaces for the stamp, I belive the name was the redi-ifix web server ?
I have a industrial use for those, combined with a stamp will make for a good ethernet compatible HVAC motor start and stopping network.
Ryan
Will
The only reason I went to this solution is because the Redi is no longer available- My goal was to get the easiest possible TCP/IP connection to a BS2 (and SX!) that I could.
Ryan
Post Edited (clayjay) : 6/8/2005 8:14:35 PM GMT
There are two Siteplayers now. One's a Serial-to-Ethernet converted (Siteplayer Telnet)
and the other, and older, version is now the Siteplayer Server. The latter is probably
what you would want. It's basically a server but it can send UDP packets as well. If
a program on a PC elsewhere on the LAN runs a program that listens to certain UDP
packerts it could, in turn, forward the data in those packets to a mail server.
An application that does this is available from the Siteplayer website. Go to the Siteplayer website
then click on the Siteplayer Server picture (lower right-hand corner). On that page click on
"Applications" near the top. Download the application UDP2EMAIL -- this requires Visual
Basic. It is functional!
Would this do the trick for you?
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
I don't know how....but I've read bits and pieces on the Net about how to do it!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Ryan
Ryan
I'm expecting a Netburner replacement for the Red-I within about two weeks. They're developing a similar instruction set specifically for us. Preliminary cost estimates are slightly higher than the Red-I.
Parallax is not designing our own internet device. This is something we'll source from a third party. It would be coupled with our own documentation and examples.
Ryan
What's the latest with the NetBurner?
-Rusty-
http://www.netburner.com
