controlling two servos at the same time
I would like to use two servos to rotate the same piece of pipe on my robot with one servo on each side of the pipe.· One of them will therefore be going in reverse in relation to the other.· If I have their pulsouts going right after one another, will the small delay in processing in the stamp be important enough to cause them to be off·of time with each other.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Second of all, I think the Servo comparator wants to get 'refreshed' every 20 mSec. If you refresh both servo's, then wait 20 mSec, both should keep rotating at the same rate. Then the only problem would be that very brief 100 uSec delay between #1's pulse and #2's pulse on startup. I don't think it would be a problem.
Jon Williams
