When will the new developer board be on the Parallax website?
The most recent issue of Nuts and Volts shows the new dev board...when will it be up on the Parallax website?
Just curious...
Ryan
Just curious...
Ryan
Jon Williams
Dallas, TX· USA
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Yeah, I was figuring it was something like that! [noparse]:)[/noparse] And of course I plan on ordering one ! [noparse]:)[/noparse]
Ryan
Jon Williams
Dallas, TX· USA
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
If you've got the May issue of Nuts & Volts you can read about it in my column.· It works with all of our micros: BS1-IC, BS2-family, Javelin Stamp, and the SX28.· I use the PDB for developing SX82-based coprocessors (using SX/B) for BASIC Stamps.· The PDB absolutley rocks, and it's about the only tool I use anymore.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 5/6/2005 2:53:58 PM GMT
bugg
Boe-bot: $229
Toddler: $249
Jon Williams
Dallas, TX· USA
bugg
Boe-bot: $229
Toddler: $249
Jon Williams
Dallas, TX· USA
The new Parallax Professional Development Board is now available:
http://www.parallax.com/detail.asp?product_id=28138
Let us know if you think the description or documentation are missing anything you would like to know.
Sincerely,
You know, I was thinking...there might be a good market for 'kits' that help you take a project designed on a board like the BOE or now this new dev board, and move to a permanent project-
For example, the 2.1mm plug, the 7805 (or what ever v-reg), socket for the uController, etc...along the lines of the carrier boards- or an inexpensive through-hole bare PCB version of the dev boards, like the BOE, etc. Just a thought.
Ryan
kelvin
You've got every accessory possible on that board...
Well, with the possible exception of the kitchen sink...
If I didn't already have an experimenter board 3 times the size, I'd jump on this board immediately.
Maybe next year...
If the BS3 is out by then...
(I can always hope, can't I?
Chris I.
bugg
Boe-bot: $229
Toddler: $249
·· What are you talking about?· All the chips you mentioned come on the board.· The LM386 is right above the speaker, the MAX232E is right above the lower DB9 connector and the L293D is right to the left of the speaker.· Order one and you'll see...
Chris Savage
Parallax Tech Support
csavage@parallax.com
bugg
Boe-bot: $229
Toddler: $249
Ryan
