How to control a servo with BS2p-24?!?
I want to control a servo motor with my BS2p-24 & BS2p-24 Demo Board. I do not see any servo plugs
I don't know how to wire it, like the BOE or maybe the homework board? My demo board doesn't specifically match anything from "What's A MiCon?" book. Please help!
Thanks!
Robotics
ro-bot-ics (noun)
the science or technology of robots, their design, manufacture, application, use, etc.
I don't know how to wire it, like the BOE or maybe the homework board? My demo board doesn't specifically match anything from "What's A MiCon?" book. Please help!Thanks!
Robotics
ro-bot-ics (noun)
·· If you have a 3-pin header, you can connect the Servo through the breadboard.· Just connect the black wire to Vss, the Red wire to Vdd and the White wire to a Stamp pin.· Then, you can use the code from the "What's A Microcontroller?" text, but you must change the pulsout values for the BS2p, as they are different timing from the BS2.· If you don't have the 3-pin header, you may still be able to do it using wires carefully from the Servo plug to the appropriate connections on the Demo Board.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I can wire it like the Homework board...but that means I need to purchase a 3-pin header...oh well.
Thanks for your help!
Robotics
ro-bot-ics (noun)
For the BS2p, the pulsout values for the "standard" servo positions would be:
1.0 ms = 1250 (left)
1.5 ms = 1875 (center)
2.0 ms = 2500 (right)
The values are calculated by taking the servo position (in microseconds) and dividing by 0.8 (the PULSOUT unit for the BS2p).
Jon Williams
Dallas, TX· USA
Robotics
ro-bot-ics (noun)
Jon Williams
Dallas, TX· USA
Thanks again!
Robotics
ro-bot-ics (noun)
························ Hacking the Trailing Edge!
················http://www.nmpproducts.com/intro.htm
················---Decks a-wash in a sea of words---
