ds1726
The ds1726 is a step or 2 up from the ds1620, I'm working on trying to interface it with my bs2. Problem is the temperature conversions are taking place, but I don't think that I'm getting the right numbers, or enough bits are being read in. I have to divide DSDATA by 17 to get it anywhere close to the actual temperature, and I'm not getting any resolution for a fraction of a temperature. The datasheet for the 1726 is available here. I'm new to this kind of thing and would really appreciate any help I can get.
' {$STAMP BS2} ' {$PBASIC 2.5} 'PIN CONSTANTS DQ CON 0 CLK CON 1 RST CON 2 DSDATA VAR Word SIGN VAR DSDATA.BIT11 T_SIGN VAR Bit RCONFIG CON $AC WCONFIG CON $0C CPU CON %10 NOCPU CON %00 ONESHOT CON %01 CONT CON %00 STARTC CON $51 STOPC CON $22 RTEMP CON $AA RHIT CON $A1 WHIT CON $01 RLOT CON $A2 WLOT CON $02 TEMP VAR Byte LOW RST PAUSE 100 HIGH RST SHIFTOUT DQ,CLK,LSBFIRST,[noparse][[/noparse]WCONFIG,CPU+CONT] LOW RST PAUSE 100 HIGH RST SHIFTOUT DQ,CLK,LSBFIRST,[noparse][[/noparse]STARTC] LOW RST AGAIN: PAUSE 1000 DEBUG CLS HIGH RST SHIFTOUT DQ,CLK,LSBFIRST,[noparse][[/noparse]RTEMP] SHIFTIN DQ,CLK,LSBPRE,[noparse][[/noparse]DSDATA\12] LOW RST T_SIGN = SIGN DSDATA = DSDATA/17 DEBUG SIGN IF T_SIGN = 0 THEN NO_NEG1 DSDATA = DSDATA|$FF00 DEBUG SDEC DSDATA NO_NEG1: DEBUG SDEC DSDATA," DEGREES C",CR DSDATA = (DSDATA */ $01CC) IF T_SIGN = 0 THEN NO_NEG2 DSDATA = DSDATA|$FF00 NO_NEG2: DSDATA = DSDATA + 32 DEBUG SDEC DSDATA," DEGREES F",CR SHIFTOUT DQ,CLK,LSBFIRST,[noparse][[/noparse]STOPC] GOTO AGAIN
·· I see nobody has replied to this thread.· I don't have a DS1726 or I would test your code.· I use the DS1620 so I have code for it, as well as several to test.· Oddly the 1726 is listed as a replacement for the DS1620, however the DS1620 is capable of .5 degree C measurements, and the DS1726·only 1 degree.· Also the DS1620 appears to have a wider temp range, unless I am missing something.· If you cannot get it working properly, it might be easier to try using the DS1620 instead, if it fits your requirements.
Chris Savage
Parallax Tech Support
csavage@parallax.com
the 12-bits that you'll read in, the lower 4 are your fractional temperature bits. Alas,
the Basic Stamps only handle integers and the arithmetic is UNSIGNED! Alas, you're
reading a SIGNED FIXED POINT number from your 1726 so you'll have to do a little bit
twiddling to get it right.
Second, dividing a negative number with an unsigned division operator will definitely
get you some very wrong numbers! Don't do it! Your best bet is to do an ABS() on
and turn it into a positive number. Remember to save that sign bit though for your
output!
Thirdly, since the BS2 doesn't do floating point you'll need to do more bit twiddling
to get your fractional temperature -- just dividing your number by 16 (17 was incorrect)
won't get you anything but the integer portion of the temperature.
In pseudo-pbasic, what you'll need to do is this after your SHIFTIN
I think you tried to use some of the 1620 code from the N&V 1620 article.
Keep in mind that the 1620 only had 9-bits of data with only 1-bit for fractional
temp. while the 1726 has 12-bits of data with 4-bits of fractional temp.
I'll leave the conversion to Fahrenheit as an exercise for the reader.
Chris, cover me on that code above. My PBASIC ain't so hot. There may be
correct ways to do this.
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
·· Regardless of the code, you went farther than I did!·
Chris Savage
notes:
-- DSS is an alias name for the sign bit of the twos complement number
-- making nib3 equal to bit11 extends the sign to 16 bits.
-- The resolution of the sensor is 1/16 degree. The */ 160 operator makes it 1/10 degree.
The */ 160 operator works on the absolute value of the number. The operations with DSS restore the sign bit,
based on the definition of negation in twos complement arithmetic.
-- The first DEBUG displays the signed value of degrees times 10.
-- The second DEBUG displays the value with the decimal point to 0.1 degree, with sign.
I haven't used the DS1726, but I think this will work.
Tracy Allen
www.emesystems.com
and have it come out right. Oh, and shifting a negative number doesn't work as division
either so.... Best thing to do is to just get the absolute value, hold the sign off somewhere,
and dink with the value from there.
Most everyone should be able to figure out everything else there except for that magical
625. Where did THAT come from? Hehehe --- well, there's 4 fractional BITS so that
Least Significant Bit has a value of 1/16 which is 0.0625. So, that fractional nybble is
(0 to 15) * 0.0625 or (0 to 15) * 625/10000. Now where's that /10000? Don't need it!
We just want the four decimal digits and that's where the DEC4 comes in... it zero left fills.
While Tracy's code will probably work, I believe that mine will give 'stin93r' all available
resolution of the DS1726 although who REALLY wants more than a single
decimal digit of temperature?
Sorry, it probably took me more time than most 'cause I tend to think in 'C', not PBASIC
and I had to do the translation.
Oh, and I just noticed that conversion time for 12-bits of precision is about 750milliseconds
if that makes any difference.
-Rusty-
DSDATA.NIB3=-DSDATA.BIT11····'·extend·sign·from·12·to·16·bits
in the program I posted. I left off the minus sign. To extend the sign from 12 to 16 bits, it needs to set all 4 bits of the high nibble equal to 1, when bit 11 of the A/D conversion is equal to one, otherwise leave them all equal to zero.
I agree that Rusty's approach will work too, with 0.0625 degrees per bit. There are often many several approaches these problems, stin93r, and the method you choose will depend on what else you need to do with the numbers, and how well you understand the methods. The methods are tools--More tools, more experience, more fun!
Note that the older DS1620 can give better than 0.01 degree, by reading its high resolution registers. The resolution of the main registers is 0.5 degree C.
Tracy Allen
www.emesystems.com
1.) What is the dsdata.nib3? I've been looking through pbasic documenutation and didn't quite understand what a nib is.
2.) DSDATA = DSDATA | $F800 (Not quite understanding the | $F*00, could someone clarify please?)
3.) DSDATA & $0f (Same as number 2)
Sorry for the questions that probably seem like nothing to you. I've done some research and still have a hard time understanding what's going on with those 3 statements. I appreciate any help I receive.
2. Setting the upper bits corrects the value when it is negative; this is required to use the number later
3. This operation is isolating the lower nibble of that value
Jon Williams
Dallas, TX· USA
DSDATA.NIB3 = - DSDATA.BIT11
IF DSDATA.NIB3 = DSDATA.NIB2 THEN ....
You can also give those chucks alias names, as in
DSC VAR DSDATA.NIB3
DSS VAR DSDATA.BIT15
and then use the alias names in place of the business with the dot.
2. Xvar | $F800 The pipe character "|" is an operator that means bitwise OR in STAMPese. It is a mask, and the result will have all the bits from number 11 to number 15 forced to 1, and bits 0 to 10 will have whatever value they have in Xvar.
3. Xvar & $0F The "&" is the operator for bitwise AND. A mask, and the result will have all bits from 4 to 15 forced to zero, and bits 0 to 3 retain whatever value they had in Xvar.
Tracy Allen
www.emesystems.com
