decoding NEMA 0183 — Parallax Forums
decoding NEMA 0183
Macgman2000Macgman2000 Posts: 59
edited 2005-05-16 02:27 in General Discussion
Hello All,
I hacked an old·"hockey puck" GPS using 4800bps 8N1, ASCII format. It's an old TravRoute serial GPS·I got for free. I want to decode the current position data stream and display on an LCD. Is there any sample code for doing that? or any help will be appreciated.
Best Regards,
Nick
  • David BDavid B Posts: 593
    edited 2005-05-12 18:19
    Are you planning to use assembly or basic? There is an entry in the projects forum where a BS2 processes GPS data for a model rocket project - have you seen that?
  • JonbJonb Posts: 146
    edited 2005-05-12 18:59
    NMEA is quite simple to decode with a basic stamp. Jon Williams has some code which is widely used to accomplish this task. I suggest doing a search for NMEA.
    Post Edited (Jonb) : 5/13/2005 4:22:20 AM GMT
  • Macgman2000Macgman2000 Posts: 59
    edited 2005-05-12 20:14
    I was hoping to use Basic language. I have not seen the post regarding the BS2....I will look for it.
    Thanks!!!
    Best Regards,
    Nick·
    edited 2005-05-12 20:19
    Check our "Nuts & Volts" reprints -- I've done a couple articles on BASIC Stamps and GPS; one does decode NEMA 0183 strings. It would take a little bit of work, but it could be ported to SX/B.
    Jon Williams
    Dallas, TX· USA
    edited 2005-05-13 17:53
    Hello Jon,
    Can the·Serin command·loop on a qualifier. Ex,·wait to see $GPGAA then start·counting off commas until you get to the byte of interest?
    Best Regards,
    Nick
    edited 2005-05-13 20:14
    What you'll want to do is put SERIN into a subroutine (so that it only compiles once), then you can do something like this:
    Wait_For_GPGAA:
    · RXBYTE @serByte
    · IF serByte <> "$" THEN Wait_For_GPRMC
    · RXBYTE @serByte
    · IF serByte <> "G" THEN Wait_For_GPRMC
    · RXBYTE @serByte
    · IF serByte <> "P" THEN Wait_For_GPRMC
    · RXBYTE @serByte
    · RXBYTE @serByte
    · IF serByte <> "A" THEN Wait_For_GPRMC
    · RXBYTE @serByte
    ·After that you can put the RXBYTE call into a loop to skip over as many characters as you need to skip.
    Jon Williams
    Dallas, TX· USA
    edited 2005-05-13 22:50
    Hello Jon,
    I guess I am not up on all the coding tricks. I can't see how it all works. Let me see if I understand, set up SERIN in a subroutine that is polled? Then go to WAIT_FOR_$GPGAA? Is there a tutorial I can reference, I am not familiar with this coding method. I guess I have been using PicBasic Pro for too long and stuck on that type of coding.
    Best Regards,
    Nick
    edited 2005-05-13 23:04
    Your best refence is the online help file. The January issue of Nuts & Volts has a SX/B project in my column that uses the strategy outlined above -- it should help.
    Jon Williams
    Dallas, TX· USA
    edited 2005-05-14 03:13
    Hello Jon,
    I read the Jan edition and reviewed the SX/B help section regarding SERIN. I was able to get my GPS to work.·I compared the data·on my LCD with·a magellen handheld and it checks out.
    Thanks for your help!!!!
    Best Regards,
    Nick
    Excellent! I'm pleased to hear it -- perhaps you could share your code and project schematic in the Projects forum; I'm sure it would be of interest to many forum members.
    Jon Williams
    Dallas, TX· USA
