decoding NEMA 0183
Hello All,
I hacked an old·"hockey puck" GPS using 4800bps 8N1, ASCII format. It's an old TravRoute serial GPS·I got for free. I want to decode the current position data stream and display on an LCD. Is there any sample code for doing that? or any help will be appreciated.
Best Regards,
Nick
Best Regards,
Nick
Post Edited (Jonb) : 5/13/2005 4:22:20 AM GMT
Thanks!!!
Best Regards,
Nick·
Jon Williams
Dallas, TX· USA
Can the·Serin command·loop on a qualifier. Ex,·wait to see $GPGAA then start·counting off commas until you get to the byte of interest?
Best Regards,
Nick
Wait_For_GPGAA:
· RXBYTE @serByte
· IF serByte <> "$" THEN Wait_For_GPRMC
· RXBYTE @serByte
· IF serByte <> "G" THEN Wait_For_GPRMC
· RXBYTE @serByte
· IF serByte <> "P" THEN Wait_For_GPRMC
· RXBYTE @serByte
· RXBYTE @serByte
· IF serByte <> "A" THEN Wait_For_GPRMC
· RXBYTE @serByte
·After that you can put the RXBYTE call into a loop to skip over as many characters as you need to skip.
Jon Williams
Dallas, TX· USA
I guess I am not up on all the coding tricks. I can't see how it all works. Let me see if I understand, set up SERIN in a subroutine that is polled? Then go to WAIT_FOR_$GPGAA? Is there a tutorial I can reference, I am not familiar with this coding method. I guess I have been using PicBasic Pro for too long and stuck on that type of coding.
Best Regards,
Nick
Jon Williams
Dallas, TX· USA
I read the Jan edition and reviewed the SX/B help section regarding SERIN. I was able to get my GPS to work.·I compared the data·on my LCD with·a magellen handheld and it checks out.
Thanks for your help!!!!
Best Regards,
Nick
Jon Williams
Dallas, TX· USA
