parallax ping sonar ranger — Parallax Forums
stamp_demonstamp_demon Posts: 69
edited 2005-05-12 18:42 in Robotics
Hello, I was wondering if anyone had tryed using the parallax ping(sonar ranger)? I recived mine in the mail about a week ago, but have yet to get it to work for me yet. _Duane
    edited 2005-05-11 02:48
    Duane,
    ·· What seems to be the problem with it?· Have you connected it according to the docs?· Tried the example code?· What are you getting?
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2005-05-11 15:10
    I have one of these, and just for testing (when it first got here) I tried the examples, and they worked just fine.
    Ryan
    edited 2005-05-11 16:43
    How do they compare to the older Ultrasound?
    Other than less wires, do they really have a narrower beam and more accurate focus?
    Is the range superior?
    I have a robot that is using IR for obstacle sensing, but the IR can only see white or near white.
    Obviously, I either have to add ultrasound or replace the IR completely with ultrasound.
    I am not sure that one sensor is enough.
    G. Herzog in Taiwan
    edited 2005-05-11 16:58
    Kramer,
    ·· This information is available in the PDF document on the product web page.
    Chris Savage
    edited 2005-05-12 16:21
    Ah, Could we get a link to those PDF documents put into the forum?
    As it is, I have to open another web page, go to Parallax and then look around.
    It seems a bit round about.
    Also, you seem to have removed any support documents [noparse][[/noparse]other than Nuts & Volts articles] for the Daventec Sensor.· So how can I actually compare?
    G. Herzog in Taiwan
    Post Edited (Kramer) : 5/12/2005 4:28:56 PM GMT
    Hello,
    · Yes, a little work would actually be required to compare the products.· You would need to go to the product pages for the products you wish to compare, and download the relevant information from those pages.· As the Devantech is a discontinued product, you would need to go to their site to get that information.
    Chris Savage
