STAMP and the Calculus
John Kauffman
I'm thinking through a short course for high school students that would use STAMP projects to illustrate concepts in high school math. Or, to think conversely, use math to enhance understanding of STAMP projects.
The basics lay out pretty well. For example:
- use a simple link attached to a servo to illustrate trig functions to calculate the link's horizontal travel from a given pulse width
- use a set of resistive values from a photoresistor to create an equation of y=mx+b
Let me know if you want to see the outline in its rough form (at this point just general ideas for topics & projects)
The students will have:
- WAM text and kit
- Floating point coprocessor (uM-FPU V2 Parallax part #604-00030a) or we might do this seminar without coprocessors
- I could add a component or two if they could make a good project
The students have done all of WAM and most have done something more with Stamps (BAaD, BoeBOT or SX/B)
The students are at different levels of high school, but for the question below the readers will have completed or be half-way through high school calculus.
At this point I am looking for examples in two areas:
Calculus - a project illustrating differentiation
Calculus - a project illustrating integration
Has anyone used calculus in a project or has an idea for a simple project that could be used to demonstrate differentiation and integration with the STAMP? Even rough ideas would be fine, I can probably chew them into something usable.
Thanks.
- WAM text and kit
Thanks.
Using a loop routine, differential measures are demonstrated by taking change in temperature between loops.
Integral measures are demonstrated by summing temperature errors over a series of loops.
The concepts are displayed using StampPlot lite.
Look at it here: The manual is a free download.
http://www.parallax.com/detail.asp?product_id=28156
I recommend you to visit this link:
http://www.emesys.com/BS2index.htm#math
Maybe it doesn't have exactly what you're looking for but it has a lot of Math resources generated by Tracy Allen.
Aristides Alvarez
Education and Technical Support Manager
aalvarez@parallax.com
Parallax, Inc. www.parallax.com
Larry
http://forums.parallax.com/showthread.php?p=529609
Tracy Allen
www.emesystems.com
Oh, and you CAN have integrators and derivators made out of op-amps and capacitors, as Tracy said above, and monitor their outputs with the BS2.
