Creating Posts Using MSWord — Parallax Forums
Jon WilliamsJon Williams Posts: 6,491
edited 2005-05-02 22:49 in General Discussion
Formatting Large Posts In Microsoft® Word
From time-to-time we will want to make a very large post and using the forums editor is not the most elegant way to edit. ·Step in our old friend MSWord – makes formatting very simple and even does spell check.
Color-coded Program example:
[noparse][[/noparse] Initialization ]
Reset:
· DEBUG CLS
· GOSUB Device_Check
· IF (devCheck = NoDevice) THEN
··· DEBUG "No device present.", CR,
········· "Please connect DS1996 and restart."
··· END
· ELSE
··· OWOUT OwPin, OwFeRst, [noparse][[/noparse]RdRom]·············· ' send Read ROM command
··· OWIN· OwPin, OwBeRst, [noparse][[/noparse]STR romData\8]······ ' read serial number & CRC
··· #IF Show_ID #THEN
····· GOTO Button_ID
··· #ENDIF
··· IF (romData(0) <> DS1996) THEN
····· DEBUG "Invalid iButton device.", CR ,
··········· "Please connect DS1996 and restart."
····· END
··· ENDIF
· ENDIF
Jon Williams
Dallas, TX· USA
  • MacGeek117MacGeek117 Posts: 747
    edited 2005-02-06 20:31
    Thank you for the tip, Jon!
    bugg
    So many projects, so little time.
  • JamesonianJamesonian Posts: 26
    Cool!
    "Shoot for the moon, if you miss, you'll·land among the stars."
