upgrading with a serin command
hello everybody
I·want to upgrade a number with a serin comand.
We going to use that number for counting down when a input is going high.
when that number is zero then we must upgrade it with any number that we like to choose.
greetings erik
greetings erik
·· What exactly is your question?· Are you trying to input a number via SERIN?· DEBUG?
Chris Savage
Parallax Tech Support
csavage@parallax.com
What we like to do is.We have a number, when a input is going high then the number is counting down from ten to nine and a output is going high for 5 seconds when this number is zero and the input will be high then the output stay low only when this number is be higer as zero then the output will be going high.
now we like to upgrade this number with serin command or something like that.
i hope you understand now a litle bit what we going to try to do.
greetings erik
___________________________________________ In | ___| I dont know what goes on with this signal past triggering Count 10 9 8 7 6 5 4 3 2 1 0 _______________________ Out | | _______________________________________________| 5 second duration |____·· Without your existing code, it would be difficult to tell you the best way to implement this into your existing code.· Please post your existing code.
Chris Savage
