IR leds
I tried to use one of my IR leds that came with my BOE bot kit today and I couldn't get it to work. Are there any tests with a multimeter or something that I can perform on it? Any suggestions on what to do?
Thanks for your help,
Jason
Unreal tournament 2004 rox
Jason
Note it is a diode, so only conducts current in one direction. You might try turning it around to see if it lights up then.
The next test you can do is shine its light (using FREQOUT 38500) at an IR-detector, and see (with a voltmeter) if the output of the IR-detector goes low.
Jason
-Jason
If I contact them, should I use this address?: sales@parallax.com
Jason
Thanks again,
Jason
http://forums.parallax.com/forums/default.aspx?f=5&p=1&m=71788#m71822
Before continuing, double check and make sure you had the IR LED we suspect is defective plugged in with the correct polarity. The "anode leads" shown on page 239 (Figure 7-5) are the longer leads. Make sure you connected the longer lead to the resistor and the shorter lead to Vss (along with the middle pin of the IR detector).
Jason
·· Please e-mail me your full name and mailing address for a replacement IR LED.· Also, let me know if you tested the other LED so we can confirm that you have at least one working unit.· My e-mail address is below.
Chris Savage
Parallax Tech Support
csavage@parallax.com
