A simple question for a first post about an LED moving display
Hi all..
I've search for some info here and found some which is great but still need a little advice. I have a slot machine that needs a LED display for the top of it. Well I need it, not the machine
. It has to be a custom made display which I have all the items to·build it, I hope so anyways here is my question.
Will the BS2 run this display of lets say 360 LEDs? It may be less but not more. I am content on using a pc to run it with just a basic message burned in but just learning about the basic stamp this week really has me going.
Maybe someone could point me in the right direction or have a link to where I might find more info?
thanks for the read and take it easy....
slotcarz
. It has to be a custom made display which I have all the items to·build it, I hope so anyways here is my question.Will the BS2 run this display of lets say 360 LEDs? It may be less but not more. I am content on using a pc to run it with just a basic message burned in but just learning about the basic stamp this week really has me going.
slotcarz
Check out the MAX7221 or MAX7219 LED driver.· Here is a link for more information:· http://www.parallax.com/detail.asp?product_id=603-00001·.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
As Dave said, check out the info on that chip. The literal answer to your question is- no. The stamp wont drive that many LED's without help. It is too much current draw for the stamps pin's. By using the MAX 7221 or 7219 the stamp is freed from having to directly drive the LED's.
Shawn Lowe
Shawn Lowe
Remember - No matter where you go
There you are.
I really appreciate the help.
cya
slotcarz
Dave
Dave Andreae
Tech Support
www.parallax.com
I want to make everything as clean as possible. Thanks Dave..
