Standard Potentiometer to a Digital Potentiometer — Parallax Forums
DigitalDjDigitalDj Posts: 207
edited 2005-03-29 01:12 in General Discussion
I want to replace a standard potentiometer with·a digital potentiometer and·use PWM 0-5v or serial but not sure how these two options may work work with the digital potentiometer.
Can anyone help and explain how this may work!
Digital
    edited 2005-03-28 23:07
    One of the great (underutilized) resources available for BASIC Stamp users is our library of Nuts & Volts columns.· They're available on our web site as PDF files.· There's an older article that should get you going:
    http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv18.pdf
    Jon Williams
    Dallas, TX· USA
    edited 2005-03-28 23:09
    We need more information here....
    What is the resistance value of the potentiometer you want to replace?
    What voltage requirements are you looking at with your current potentiometer?
    "...PWM 0-5v or serial..." to do what? to set the value of the digital potentiometer?
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    Latest Company News
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
  • DigitalDjDigitalDj Posts: 207
    edited 2005-03-28 23:33
    Thanks Jon i will check the article out!
    Beau,
    100K
    Line in audio so we are talking millivolts?
    Yes the PWM or Serial to set or adjust the digital pot
    Digital
    edited 2005-03-28 23:52
    Jon,
    Would you know what the serial bytes would be for the DS1267 if i was programming in visual basic and how would i go about using 2 of these?
    Digital
    Post Edited (DigitalDj) : 3/29/2005 12:31:04 AM GMT
    Nope, you'll have to read the article and download the docs for the DS1267 -- I've never used it myself.
    Jon Williams
    Dallas, TX· USA
