Dead serial connection
My BS2 isn't showing up in the Stamp Editor. It was working a few minutes ago, and nothing has changed in my hardware setup. Loopback and echo are both coming up with "yes". The stamp is definitly powered, and my serial connection seems to be fine. The only thing that I've found that might be·the cause·is that·a 5V regulator in my curcuit seems to be outputing 9V.·It isn't connected to the stamp in any way besides sharing the same 9V power supply. Could this be a problem? Has anyone else ever had this sort of thing happen? I've never seen a voltage regulator do this before, but it seems unrelated.
Jon Williams
Dallas, TX· USA
Oh well. Thanks!
