rechargeable battery on board? I have access 2intermittent power @ a mechanica
Hi Everyone,· I am really enjoying learning stamp working from reading the vast prior discussions.· I am an artist and have a robotic piece that spins around on a bearing made out of a VCR head with a two track "motor brush" style power feed.· It is 12V and runs a bunch of motors, and a car antenna device which I have rigged to do something else.· It appears to feed power continuously, but even with a second pair of brushes, I think there are imperceptibly brief interruptions, which cause the stamp to be in a constant state of reset.· So I have a 9v battery which can drive a couple relays and the stamp, but I need to ship this thing to an out of state show.· Ideally I need·a circuit to trickle charge the 9v, so it is always engaged, but I dont really understand this kind of electronics, and most circuits seem to require everything else be disconnected to charge.· I won't be there and the curator or registrar will definitely not change batteries for me.
Does anyone have an idea?
The transister driver idea already saved my bacon on the relay.· Thanks again for an active and informative forum.
Randy Polumbo
randy@3-dcon.com
www.polumbo.com
Randy Polumbo
randy@3-dcon.com
www.polumbo.com
The type you purchase at about any drug store, gas station or grocery store? To my knowledge those are not rechargeable.
Do you have a schematic of your circuit you can post?
Any idea?
thanks R
It is a pulse charger and helps to prevent deterioration of the rechargeable lead acid batteries. Have lead acid rechargeable batteries here still working 10 years later and in good shape.
73
spence
k4kep
I assume if I just connect the 12V to the power with nothign in between the cel could blow up or something if it was plugged in too long.
Thanks R
and 73 ( KB2SDZ)
Can't you just use a resistor from the 12 Volts to the 9 Volt battery ???? R-330 Ohm would give you about 10 mA charge current.
Klaus
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
That works for me if it works for you.· What if:
1.·the 9v battery is powering the stamp, as it is being charged?
2. the battery is being charged CONTINUALLY 24x7 including when there is no stamp running. won't it blow up after it is full?
Thanks R
I don't understand how a capacitor can discharge over time. I just recall flipping the little ones at my brother after I charged them with·a 9v battery.· It helped him stay awake in 4th grade. [noparse]:)[/noparse]
THanks R
It sounds like the BS1's power is getting 'browned-out' (ie voltage lowered to the point where it resets the BS1) by the motors. The 'local' capacitor to the BS1 may reduce the impact of brief dips in the motor voltage.
do you think your solution might work to address this?· If so where does the diode go, between the cap, and the stamp, on the positive.?
Thanks R
Then the diode with the arrow pointing towards the BS and cap, and the other end going to the supply.
Bean.
www.sxvm.com
1N4001 --->|-----o------- | | + ===== 220uF, 16 volt or 25 volt | | -----------o--------On the left side input the noisy power from the brush system. On the right side, your Stamp. Keep the leads on the right short. The capacitor stores enough energy to keep the Stamp running during the brief interruptions in power during the time the brushes bounce. I don't think you need an additional battery.
Tracy Allen
www.emesystems.com
Best R
Thanks so much.
Randy
I've always wanted to build stuff out of metal and electronics that do stuff. It never occurred to me that this could really be art. I'm so glad that the diode and capacitor worked, now I can say I had a small input into something beautiful.
Note if you go to a BS2, the BS2 may reset more often. The BS1 is MUCH more tolerant of low-voltage power than the BS2 is.
I had the thing working again, and somehow I think I fried the BS1.· I am curious if running it at 13.8 volts is too high.· I tried adding the 330 Ohm R in series on the + and maybe I forgot ohms law, but it seems to still be at 13.8.· I have a new stamp in and it seems to be running, but I cannot figure out what fried the other one.· I have to ship this thing out of state for a show, and I dont mind if they have to reset it, but I will be sunk if I have to fly there and change the BS1 periodically.· Ouch.
Thanks R
PS Here is the animation if anyone wants to see it.· It is way oversimplified, the thing also rotates 360 both ways on air power and extends 5'
I haven't dealt with the BS1 yet, so you're out of the areas I know stuff about.
Is there a smarter compact way to make 9-12 out of 13.8?
Thanks R
Shouldnt the stamp run on +5V? Excuse me if this is a really stupid question.
I ordered some of the regs you mentioned from DIGIKEY in the meantime.
Thanks R
The BS-1 can be powered from one of two pins, either Pin 1 or Pin 5. If you are supplying an unregulated voltage, or a voltage greater than 5.5 VDC, you use Pin 1 which will accept a range of voltages from 5.5 --> 15 VDC. If you have a regulated voltage between 4.5 --> 5.5 VDC you can apply that to Pin 5 instead. One or the other pin can be used, but not both.
The following is just an educated guess, but I suspect it may have some merit. I suspect you are going to say that you're using Pin 1 and have that connected to your battery, and in turn a battery charger is connected to the battery. I further suspect that when the battery charger comes online it may well be producing voltages in EXCESS of 15 VDC, therein blowing the regulator on the Stamp. If that is the case, I'd place a 12 volt (approximate) Zener diode between the rechargable battery and the Stamp. This way the battery charger fully "sees" the battery and can charge it properly, but no voltage over 12 volts can reach the Stamp. Any Zener diode between 12 volts and 15 volts would work equally well if you're feeding Pin 1.
Parallax does offer a repair service for Stamps which have had their smoke let out
Bruce Bates
Now even with the 5.5v coming in on pin 5 which works great, the stamp fires the relay once, and then crashes so it cannot be found by the editor again until I power down and disconnect everything.· I am wondering if there is noise or slop downstream in this car antenna apparattus motor or something else.· I have it neither rotating or running the propellors and it still bombs out.· This is the exact problem I had feeding 13.8 into the·VIN·pin, that I thought giving it steadier fuel would avoid.
Now I am thinking it may not be the power at all, but I don't see any shorts or issues.· When pin 6 which I·using to drive the relay goes hi it is only 3V.· Is this normal?· It just barely trips the relay with the·TIP transformer circuit elsewhere on here.· Can I isolate this better somehow since the stamp will run all day on the 13.8 or on the 5.5 until I connect the relay circuit.· It is enclosed except i used a TIP3 because I had one.
Thanks R
Thanks in advance for any thoughts, I am sorry this is proving to be such a troubled little mission. I thought I was done 3x already.
Thanks R
I wonder how the BS2 will like having the battery side 50% of the board cut off on my band saw.
Thanks R
