How to connect /network 2 or more BS2 stamps ?
I'm very new to this hobby, and the reason that i'm interested is that I need to build a machine control system. I need to build a system that has 20 output pins, and 20 input pins. (or about)
·My question is: can I setup a communication system where I can input a high signal on pin 1 stamp 1, and
specify that if (pin1,stamp1) is high,· then (pin 14, stamp3) is high. and so on...
welcome any suggestions!·
Ken
P.S. How can I amplify the stamp output signal to run a electrohydralic porportional·valve coil that peaks at 12v,3amps ?
·· Suggestions?·Your project covers several of the fuzzier areas of control projects. In order to make any headway at all, you're going to have to break your project into bite sized pieces. I'd suggest the following approach ( with the Stamp Help files firmly in hand!):
··· 1. Take Stamp 1 and program it so it uses serial output to send some data to a PC or laptop. It will reinforce your understanding of baud rate, transmit parameters and string manipulation.
··· 2. Take Stamp 1 and set it up to receive a few characters from a PC running either the stamp debug screen or Hyperterminal. Experiment with getting the stamp to receive a certain character then turn on a particular output. Again, this will increase your understanding of the serial communications.
··· 3. Now, get stamp 2 to receive some data from stamp 1. Use the Stamp help file description of the Serin/Serout commands. There are some good examples there that will get you to a working example quickly.
··· 4. Controlling the valve will require some understanding of PulseWidth Modulation. I've used the stamp PWM control to operate the control valve for a 2000 Ton marine railway. To get the·stamp output current up to the usable range, I used an IRL520 transistor. Note that if there is a lot of code running on the stamp, you may have to use an external PWM controller in order to get smooth control. Parallax offers an add-on module.
···5. To get more inputs/outputs you could consider some of the addressable chips like the '595 and similar ones.
Cheers and Good Luck.
Tom Sisk
Use one Stamp and two 74LS165 (IN) and two 74LS595 (OUT). The shift registers will use 3 of the Stamp pins for serial I/O. This give you 16 IN from the '165, 16 OUT from the '595 and 13 IN or OUT from the Stamp.
Sorry, I dont know about driving valves but if a Stamp can drive servos Im sure the solution is available.
-Paul
You can easily use a couple of I/O pins for one stamp to signal another what the first BS2's state is, if the second BS2 needs to do something based on the first BS2's state. A more flexible, but slower, interface is to use SERIN/SEROUT messages. Concievably you can even use a '595 to '164 pair to implement a single byte 'register' for storing state.
I just got back to check on this post. Y'all have given me a lot to work on.
Now, Do you think I could find someone in Houston, TX that understands all this well, and would consider helping me build this for say,..
$35,or $40 an hour?· Just wishing...
If wishes were horses, beggars would ride...
So, I'll go to work.
Thanks again
···· Ken············
