need a LOT of help here.. pressure sensors
ok so i understand that the basic stamp can pick up dc signals from 0 to 5v dc. my question is how would i obtain a signal from five of these http://www.dakotadigital.com/Detail.cfm/-/Category=105/PartNumber=SEN-03-5/product.htm[noparse][[/noparse]url] and display them onto an lcd? if you have an easy solution, email me at Pheuker@bgnet.bgsu.edu
-also, if you know of cheaper sensors, please inform me.
(this is for an air ride system by the way. i am planning to be able to display and raise/ lower pressures in each cylinder by defined intervals...replacing the 1000 dollar systems)
Does it change resistance with pressure ? If so what is the resistance range ?
What kind of accuracy do you need ? Over what range ?
If you had a link to a datasheet that would help alot.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
That said....
Most sensors of this type are designed to be a resistive element in a wheatstone bridge.
....Bean, you beat me to it
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
Latest Company News
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Post Edited (Beau Schwabe) : 3/25/2005 4:09:14 AM GMT
150ohm 100ohm 75ohm 50ohm 20ohm
112psi 68psi 48psi 28psi 7psi
I hope this helps
