need a LOT of help here.. pressure sensors — Parallax Forums
pyroturbopyroturbo Posts: 5
edited 2005-03-25 04:46 in BASIC Stamp
ok so i understand that the basic stamp can pick up dc signals from 0 to 5v dc. my question is how would i obtain a signal from five of these http://www.dakotadigital.com/Detail.cfm/-/Category=105/PartNumber=SEN-03-5/product.htm[noparse][[/noparse]url] and display them onto an lcd? if you have an easy solution, email me at Pheuker@bgnet.bgsu.edu
-also, if you know of cheaper sensors, please inform me.
(this is for an air ride system by the way. i am planning to be able to display and raise/ lower pressures in each cylinder by defined intervals...replacing the 1000 dollar systems)
  • BeanBean Posts: 8,129
    edited 2005-03-25 03:26
    Hmmm, that link does tell me anything about the sensor...
    Does it change resistance with pressure ? If so what is the resistance range ?
    What kind of accuracy do you need ? Over what range ?
    If you had a link to a datasheet that would help alot.
    Bean.
    "SX-Video Display Module" Available Now.
    www.sxvm.com
    "A problem well defined, is a problem·half solved."
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2005-03-25 04:03
    Do you have a datasheet? Looking at the link seems to be horrible as far as trying to find any specific information.
    That said....
    Most sensors of this type are designed to be a resistive element in a wheatstone bridge.
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    Latest Company News
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    Post Edited (Beau Schwabe) : 3/25/2005 4:09:14 AM GMT
  • pyroturbopyroturbo Posts: 5
    edited 2005-03-25 04:38
    I have some resistance and pressure values.
    150ohm 100ohm 75ohm 50ohm 20ohm
    112psi 68psi 48psi 28psi 7psi
    I hope this helps
    o and in addition, i need about a 125 psi in each cylinder and 200ish from the tank... have not decided which pressure switch to buy yet so maybe as much as 250
