SX/B Servo Controller — Parallax Forums
DWinchellDWinchell Posts: 60
edited 2005-03-23 17:31 in General Discussion
Hi All :-)
I was playing with the SX/B and a Tech Board this evening and decided to see if I could run Servos using the SX/B :-) Please find the result attached. It worked :-)
Thank You
David Winchell
David@Winchell.com
  • BeanBean Posts: 8,129
    edited 2005-03-21 12:23
    Here's one I wrote that uses interrupts to control 8 servos on PORTC.
    This was almost my contest entry.
    Bean.
    Check out· the "SX-Video Display Module"
    www.sxvm.com
    "A problem well defined, is a problem·half solved."
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2005-03-21 18:44
    Hey those are great. That was in my list of things to do with the SX ~
    BTW, where did you get the stand-offs you use on your dev board? I should do that....
    I love those mini servos....
    Ryan
  • DWinchellDWinchell Posts: 60
    edited 2005-03-21 21:24
    Got the heat sink, standoffs & feet at a local junk store
    Thank You
    David Winchell
    David@Winchell.com
  • Jim McCorisonJim McCorison Posts: 359
    edited 2005-03-22 04:30
    David,
    I like that extension cable for connecting the key to the Tech Board. Did you do that up yourself or find one somewhere?
    Jim
    edited 2005-03-22 07:43
    Hello Jim;
    My Wife had a crimping tool and I made it. It's just a 4 conductor straight thru cable.
    Thank You
    David Winchell
    David@Winchell.com
  • PJMontyPJMonty Posts: 983
    edited 2005-03-22 09:12
    Jim,
    Rather than extend the SXKey output (with things like the 50 MHz clock), extend the input instead. Get a pair of IDC style crimp on DB9 connectors and make a little one or two foot flat ribbon serial extender. Here's an URL for the parts at Digikey:
    dkc3.digikey.com/PDF/T051/0025.pdf
    You can also buy a 6 foot one pre-assembled at JameCo:
    www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=125957
    This removes the strain of hanging a heavy serial cable onto the SXKey, while not creating a potentially flaky connection due to running 50 MHz clocks over wires.
      Thanks, PeterM
    edited 2005-03-22 17:26
    That's just what the RevE Sx-Key did. Please see attachments. It's still work great and it's flexible :-)
    Thank You
    David Winchell
    David@Winchell.com
    560 x 420 - 37K
    560 x 420 - 45K
    Thanks all. Extending serial cable with light weight stuff is definitely a better solution.
    Jim
