SX/B Servo Controller
Hi All :-)
I was playing with the SX/B and a Tech Board this evening and decided to see if I could run Servos using the SX/B :-) Please find the result attached. It worked :-)
Thank You
David Winchell
David@Winchell.com
Thank You
David Winchell
David@Winchell.com
This was almost my contest entry.
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
"A problem well defined, is a problem·half solved."
BTW, where did you get the stand-offs you use on your dev board? I should do that....
I love those mini servos....
Ryan
Thank You
David Winchell
David@Winchell.com
I like that extension cable for connecting the key to the Tech Board. Did you do that up yourself or find one somewhere?
Jim
My Wife had a crimping tool and I made it. It's just a 4 conductor straight thru cable.
Thank You
David Winchell
David@Winchell.com
Rather than extend the SXKey output (with things like the 50 MHz clock), extend the input instead. Get a pair of IDC style crimp on DB9 connectors and make a little one or two foot flat ribbon serial extender. Here's an URL for the parts at Digikey:
dkc3.digikey.com/PDF/T051/0025.pdf
You can also buy a 6 foot one pre-assembled at JameCo:
www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=125957
This removes the strain of hanging a heavy serial cable onto the SXKey, while not creating a potentially flaky connection due to running 50 MHz clocks over wires.
Thanks, PeterM
Thank You
David Winchell
David@Winchell.com
Jim
