Logic levels — Parallax Forums
Logic levels
NewzedNewzed Posts: 2,503
edited 2005-03-14 20:42 in BASIC Stamp
What are the logic levels for a Stamp - 1.7 for a LOW and 3.4 for a HIGH?
If the pin is at 1.8-3.3, would the indicated state be the last state it was in?
Sid
    edited 2005-03-14 18:01
    Sid,
    ·· The threshold for a logic level 0 is 1.4V on the stamp.· Anything below 1.4V·is low (0), and anything·above ·1.4V·that should be high (1).
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    Post Edited (Chris Savage (Parallax)) : 3/14/2005 6:13:47 PM GMT
    edited 2005-03-14 18:34
    Sid,
    What you are describing is a schmitt trigger input which has a hysteresis region in the middle.
    The Stamp has a TTL level that trigger at 1.4V
    Stamp Manual
    See pages 138,327, and 352
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    TTL chips (Like the 74xx series), especially older logic chips do have that middle region.· But the stamp has a solid 1.4V point with .1V crossover to prevent an intermediate signal.· It's TTL compatible.
    Chris Savage
