Printing Source code (left margin option (still) broken?)
I just tried printing some of my programs for later research, and I noticed the print requestor has a field labeled "Left Margin". I could not find a reference to it in the HELP files. I'm using the Basic Stamp Editor/Development system 2.1 (dloaded about 3 days ago).
I've tried placing some values in there (.5, .75 etc) and have not been able to get printouts that give me enough room to 3-hole punch w/o poking holes in my code (there's enough in it already thankyou!
) So, can someone tell me how to set this so I can print with a 3/4 or 1" left margin? TIA!
Vern
Post Edited (Vern) : 4/10/2007 11:26:58 PM GMT
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Vern
Jon Williams
Dallas Office
Unfortunately, that feature is broken in the print dialog.· We have plans to fix it in the next release but as of yet have not determined why it isn't working properly.· Sorry for the inconvenience.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
I usually descend to printing my stuff using PFE, the "Professional File Editor". It's quite old by now, but quite capable.
Jon Williams
Dallas, TX· USA
Unfortunately, there is an elusive,·low-level error in the underlying code·that handles the "Left Margin" setting.· The software objects that provide this feature have a planned replacement (which I am working on right now) for later this year that includes a number of enhancements and fixes, including a "Left Margin" feature that works.· Because of the nature of this error and a number of other features in progress, we won't be able to fix the left margin problem until that future release (which will be after v2.2; the version about to be released at the end of this month).
I'm sorry for the inconvenience.
--Jeff Martin
· Parallax, Inc.
Nice to know a fix is in the works, at least.
Ok, so I just printed out 40 pages of source code and my 3-hole punched paper leaves holes in my source code. Frankly, there are enough holes in my code without this issue adding to it!
Any update on this issue? It's been around for what, over 3 years now?
Vern
Vern
I must be the only person left on the planet that prints source code for debugging purposes!
Post Edited (Vern) : 4/10/2007 11:28:56 PM GMT
It gives you margins, line numbering, different fonts, adjustable tabs, lots and lots of nice options.
You're not the only one who prints source code. You may be the only one who does it from the Parallax IDE, though.
Vern
Use Adobe Acrobat to open the resulting .pdf file and print it on your regular printer. With Acrobat you should have the ability to to scale the printout to fit your printer's normal margins.
The file to install CutePDF is called CuteWriter.exe, it's about 2MB. I probably got it from download.com or somewhere like that. If nothing else, it's very useful for making pdf files.
- Rick
Vern
I have not solved that error, unfortunately, and got distracted from it by other issues, but I will resurrect it again as soon as possible and will post here when it is fixed.
--Jeff Martin
· Parallax, Inc.
