could someone give me a sugestion what to do?
hi my name is kelie and i am a 13 year old·boy.·i have just discovered the vast world of microcontrolers.· ive looked at about everything on this site, and am wondering what i should get.· The board of education usb starter kit looked apealing, but would this be the right choice?· I am interested in building r/c robots, and autonomous robots.· i already have a farily decent knowledge of electronics, and building something that can operate by my programing sounds pretty cool. Any sugestions?
Jon Williams
Dallas, TX· USA
On the other hand, you can start with the BOE kit, then add the BOE-Bot parts later. The BOE-Bot kit implements a 2-wheel with 'pivot', Modified Servo driven robot with both 'whisker' and IR collision detection.
Unless you feel up to handling a Toddler, though...
What's your budget?
There's a couple of books that might help you out if you want to design your own HardWare:
The most important one is :
Robot builder's Bonanza by Gordon McComb
The others are:
Building robot drive Trains by Dennis Clark and Michael Owings
Programming Robot Controllers by Myke Predko
(The last one mostly deals with the PIC micro, not the BS2, but it can give a few clues as to algorithms)
All are available on Amazom.com or at least they were a few weeks ago...
···· Me and a few friends·are interested in building·battlebots, so·I checked out·a book·about building them.· I found a section that talked about microcontrolers, and it·talked about the Basic Stamp, and the Boe bot.·It even gave a couple of example programs. So, naturally, i just HAD to·do some research.
··· Now, about the basic stamps.·Could someone give me a little bit of a describtion or·a little more info that·isnt quite as complicated. Vin? Vss? sout? it's·sort of confusing.··Are·there any other options·to use and program the stamps rather than the Boe? somthing cheaper?·Other kinds of microcontrolers?
···· I know its a lot of questions and·again,·I wanted to again say·Thanks.
the NERD, Kelie B.
As for the BOE...
You don't NEED it to program the BS2. All you really need is a BS2 and a serial cable.
This of course assumes that your PC has a serial port.
Noticed that the OEM BS2 kit is on sale right now:
http://www.parallax.com/detail.asp?product_id=27291
If you're not too bad at handling a soldering iron, that could be a good starter kit.
Unfortunately, with your budget, you won't be able to afford a decent bot-kit, so you may have to scrounge for parts.
good places for stepper motors and their driver ICs is old inkjet printers and scanners.
There are also some good mechanical parts in these...
(Gears, cogs, belts)
5.25" and 3.5" disk drives also contain steppers. One large, flat one which can be almost impossible to get out, but which can keep a very accurate RPM, and a smaller one with a nice worm-drive.
If you can find a cheap copy of the Robot Builder's bonanza, or the Building Robot Drive Trains, you shouldn't have too much problems using the scrounged parts.
This is an introductory robot that includes a built-in BS2 - but you'll also need to buy a DB9 straight thru cable such as this one to program the robot www.parallax.com/detail.asp?product_id=800-00003
If you can't find the Tab SumoBot in stock, the next best inexpensive choice is the What's a Microcntroller BASIC Stamp kit (made by Parallex and sold by Radio Shack) available here www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=&product%5Fid=276%2D625&site=search
The kit includes a Homework Board (built-in BS2), serial cable, a good project book, and enough parts (including a servo) that will keep you busy for awhile - for $79.99. This kit has a lot more projects than the Tab SumoBot and is a better choice IMHO.
I went through something similar to what you're going through. I wanted the most cost-effective platform possible -- I was trying to get something that I could put together for a school class, that would not cost too much yet get reasonable learning out of.
The BS2 with BOE, while it may seem expensive at $150 or whatever, actually is one of the lowest cost production items you can get, with some of the best support on the www.parallax.com website.
I started out with the TAB SumoBot -- and if you can get one of those locally for $30 go for it -- it originally retailed at $99. It has a built-in BS2 on-card, so all parallax docs and code and courses work with it. Then you might spring for the Analog and Digital Interfacing class.
In theory, all you need to buy is a BS2, some Radio Shack prototyping board to plug it into, a serial cable, and a 9-volt 500 mA wall-wart power adapter, and a way to plug that into the prototyping board. In practice, all of this will cost you around $100 anyway, so you might as well go for the packaged solution.
The OEM developer's version of the BS2 is an option, as that comes with its own board, and costs less than the $50.00 BS2 module. You'll still need the prototyping board and power supply and serial cable, though.
http://www.parallax.com/detail.asp?product_id=27207
Chris Savage
Parallax Tech Support
csavage@parallax.com
···I thought that I would say a little about my self.· Im a 13 years old and·I live in Indiana.··You've heard me·refer to myself as a nerd,·and·thats what·I like·to consider my self to be.· I've always wanted to work for NASA some day, posibly as an aerospace engineer,·or some sort of mechanical or robotics engineer.· I love science and technology(obviously).· I earned enough money last summer (lots of lawn mowing) to buy a nice model airplane.· I am a member of the Barnstormers aeromodeling club, and love to fly!
···· I would like to hear about some of you guy's projects.· What kind of robots and gadgets have you guys built?·
Thanks again,
the NERD, Kelie B.
The BASIC Stamp: Like duct-tape for Nerds
We have some flyers in our office too. I know nothing about flying model airplanes, but I have built GPS loggers for them (using a BS2p) so we could find out how fast they fly (my boss's plane went about 80 mph straight-and-level) and graph the flight path.
Jon Williams
Dallas, TX· USA
the NERD, Kelie B.
The article described a Stamp application used on an RC airplane. The Stamp continuously monitored whether or not the plane was still in contact with the controller.
If the plane got out of radio range, the stamp took over putting the plane into a gentle circle, which then brought it back into radio range.
···· I still don’t know very much about microcontrolers, but would there be any way to hook my receiver up to the basic stamp or BOE and have the receiver control a relay by way of the basic stamp?· I was·thinking that it might be a possible way to control a battle bot.
···· Thanks
the NERD, Kelie B.
I wanted to use a helium ballon to float the camera and BS2 and a FRS walkie-talkie, then I would use another FRS to send a tone, which the radio on the ballon would receive then signal the BS2 to tell the camera to take a picture.
I got the whole mess working, then found out that the helium was too expensive.
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
You may want to use a 'keychain' type cheap camera instead of your Kodak, though...
The BS2 should have no trouble reading the pulses from the receiver. You can use the PULSIN command.
Bean.
www.sxvm.com
thanks,
the NERD, Kelie B.
Chris Savage
Kelie
the NERD, Kelie B.
I have seen of all these cool inventions that evryone has made, and it makes me wonder; what cant BASIC stamps do ?
Kel!e
the NERD, Kelie B.
Chris Savage
With regards to the desire of interrupts, Jon Williams explains why true interrupts aren't plausible in the stamp in the January 2005 Nuts and Volts issue, the time sensitive functions SERIN, SEROUT, PULSIN, PULSOUT, PAUSE, OWIN, OWOUT would exhibit unpredictible behaviour if there were true interrupts. BTW using SX/B (The basic compiler for the SX) gives you true interrupts as Chris explained in the previous post. Polled interrupts can be mimiced in ordinary stamp code regardless of the version.
Post Edited (Paul Baker) : 3/14/2005 3:05:49 AM GMT
Hey, I just realized I have over 100 posts. WooHoo
My dad took him to a huge public library a while back, and Kelie walked out with a stack of books with titles like "Junkbots, Bugbots & Bots on Wheels", and "Building Bots" (which is by the author of one of his favorite books, "Backyard Ballistics").· Adding this to his interest in aeromodeling, life around our household is never going to be the same again.· What's worse, is that Kelie's 9 year old brother is absorbing all of this on the sidelines.
Again, my thanks, and please be gentle on the mom!
Rebekah Bailey
the NERD, Kelie B.
We wouldn't sleep at all, we would stay up all night writing games on his Tandy CoCo computer.
His mom knew it, but I guess she figured we weren't out causing trouble, so she acted like she didn't know.
We would sneak out every couple hours to the coke machine across the street. She HAD to have known.
Bean.
www.sxvm.com
Chris Savage
I don't want to make things worse for you but just wanted to let you know that we're getting close to launch this summer a robot for ages 8+.
I'm sorry, but now even Kelie's brother will be able to jump into robotics with both feet...
I'm attaching an image of a CAD drawing of the robot.
This is a project under development, so if anybody asks you, you don't know anything about it...··
Aristides Alvarez
Education and Technical Support Manager
aalvarez@parallax.com
Parallax, Inc. www.parallax.com
