Need some wheels
Being the noobie that I am, I can't find any place to buy wheels and axle close by.· Here is my motor: http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM92MTR2258&Category_Code=MTR
My frame is roughly six inches tall and 18 inches wide.· I am using the motor to drive a single axle and a servo to drive a single steering wheel in the back.· Any suggestion on where to find the axles and wheels?
That's what I would try.
Curious.... can you turn the motor shaft by hand or does it lock?
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
One last thought is you could use a 5/16" gear or sprocket to drive an axel that you get which does match a wheel.
--==<{Chris}>==--
