Need some wheels — Parallax Forums
Need some wheels
musictechmusictech Posts: 54
edited 2005-02-06 16:21 in BASIC Stamp
Being the noobie that I am, I can't find any place to buy wheels and axle close by.· Here is my motor: http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM92MTR2258&Category_Code=MTR
My frame is roughly six inches tall and 18 inches wide.· I am using the motor to drive a single axle and a servo to drive a single steering wheel in the back.· Any suggestion on where to find the axles and wheels?
    edited 2005-02-03 20:12
    Nice motor for 10 bucks, have you checked your local hardware store for shaft couplers moving toward a lawn mower replacement wheel?
    That's what I would try.
    Curious.... can you turn the motor shaft by hand or does it lock?
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
  • musictechmusictech Posts: 54
    edited 2005-02-04 06:41
    It turns by hand, but it is fairly tight
    The specs says the shaft OD is 5/16".· You will need to find a collar/sleeve or wheel to fit that size shaft.· You could also use a coupler to switch sizes.
    One last thought is you could use a 5/16" gear or sprocket to drive an axel that you get which does match a wheel.
    --==<{Chris}>==--
