Need help designing 2.7V to 5V interface
I am interfacing the SX operating at 5V with a 2.7V SPI device with a max operating frequency of 20MHz, the SX is the master. I plan on using a voltage divider for the MOSI and Clock signals to convert 5V to 2.7V. But I am faced with a slight dilemma for the MISO line. I want a very small circuit because board real-estate is at a premium, so I don't want to go with a level shifter chip. Ordinarily I would design something like the following circuit:
············· 5V
·············· R
·············· |____ SX MISO
Slave MISO ---npn or nmos
··············GND
But this also inverts the signal, not a super-critical issue, since I can rewrite the SPI interface inverting all the MISO bits. But I cannot think of a similar simple circuit which will have a non inverting output, can anyone think of such a circuit? Additionally, given the parameters I have provided, can anyone suggest a particular transistor to use in the above circuit? (The transistor should be surface mount or have a surface mount equivalent) As you can see it is a capacitive load where the capacitance is the SX pin configured as an input. I cannot find on any of the data sheets what's the capacitance of an SX pin, so the circuit will have to be overdesigned. Also any suggestion of a ballpark for the resistor value?
Paul
Post Edited (Paul Baker) : 1/14/2005 4:12:09 PM GMT
············· 5V
·············· R
··············GND
Paul
Slave MISO
4.7K
SX MISO
···············4.7K
·············· Vss
Jon Williams
Dallas, TX· USA
Paul
PS thanks for responding, I figured you'd be able to help me if anyone could. I read your patents, my parents could use your swivel intake patent, they live on a lake that is only weakly fed by a spring. When there is very heavy rain, the silt level of the lake rises and clogs the intake to thier irrigation system, causing my mom to swim out with a shovel and dig it out. During dry and hot periods the lake level decreases so far that the intake is exposed to the air (at the time they need to irrigate the most), though your invention wouldn't help for the second situation. They have extended the pipe twice, but without fail the frequent and increasingly severe Florida droughts prove thier expenditure was in vein.
With the pullup resistor activated on the SX (the User manual gives an approximate resistance of 20k), the voltage at the SX pin can be calculated by the following circuit equivalent:
·········· 5V
········· 20k
··········· |____SX Pin
········· 4.7k
Slave___|(2.7V)
··········4.7k
·········· 0V
The current flowing through·the top two resistors is 93uA (2.3V/24.7KOhm) producing a voltage of 3.1V at the input, better but not by much. An additional complication is that this is steady state analysis,·with a switching speed of 20MHz, charging and discharging the input capacitance of the SX pin will consume·a fair amount of the 93uA causing the actual voltage to be even lower, for this reason increasing the two resistor values will not improve the situation because there would be even less current and the current consumed by the·SX pin will be a greater share of the total current.
However·after thinking of your example I think I may have come up with another·idea, using current mirrors. Ill need to draw up the circuit and analyse it. Ill post my results when Im done.
Paul
Assuming the slave MISO outputs swing near the rails, and the SX analog comparitor is fast enough a simple divider network splitting the 5 volts to 1.5 volts·into one of the comparitor inputs, or simply two diode drops above ground to the reference input, MISO to the other input, then enable and sense the output of the comparitor.
Tracy recently posted a wealth of data on the comparitor speed.
+5v
R
R
R
R
SX comparitor reference input
diode
diode
ground
Ken
Post Edited (KenM) : 1/15/2005 6:10:47 AM GMT
Ken, interesting idea, I think it·will work. The application requires so many I/O that I have to add external logic for expansion (I have >80 signal lines
Paul
Just a couple of small notes.
You mentioned freeing up an extra pin on the SX. The comparitor config I suggested will use 3 SX pins.
Ken
Paul
Just read the spec, I think I can set /CMP_EN to 0 and /CMP_OE to 1 (disable output)
Post Edited (Paul Baker) : 1/15/2005 6:52:27 AM GMT
Yeah, some brain fade on my part......
The comparitor obviously uses two i/o pins. The user has the option of turning on the output (third pin), or simply make a decision based on a bit set or clear in the W register.
Ken
Code from Guenthers book (I think)
;This SX28 code demonstrates setup of the on-board comparator.
;This code is written for the SX28 with a date code of AB9921AA (or later)
;and requires the SXKEY28L.exe software for assembly and programming.
··DEVICE·SX28L,OSC4MHZ,TURBO
··RESET·Start
··FREQ 4_000_000
Start
··;Comparator Configuration
··MODE·$08··;Set Mode to allow Comparator configuration
··MOV·!rb,#%00000000·;Set comparator on and result-output enabled
··MODE ·$0F··;Set Mode to allow Direction configuration
··MOV·!rb,#%11111110·;Set port B bit 0 output, bits 1-7 to input
Main
··MODE·$08
··MOV·!rb,#$00
··jmp·Main··;At this point, W bit 0 holds result of comparator
·····;and port B bit 0 outputs the result as well.
