Single sided SX28 PCB
I have spend·all night trying to figure out how to place the components for a sx28 circuit, on a single sided pcb, with both crystal (jumper select) and SX-Key connectors, but I just can't get it all to add up without the use of one or a couple of jumperwires.
Beeing a bit fanatic about the use of wires on a PCB, I hoped you guys could help me out.
Btw as I said, I haven't had much sleep, so I may or may not make any sence.
Why do·they call it a spacestation? There's hardly "space" for anything in there.
instead of wire jumpers, you could use zero-ohm resistors - at least, this makes the pcb look like not having any wire jumpers
Seriously, I made various pcb designs for the SX in the past but never tried to design a single sided board, and I doubt that it is possible without any jumper wires, and if yes, traces would have to be very thin, and might get long.
In the meantime, I prefer a four-layer design with one middle layer connected to Vdd, and the other one to Vss. This dramatically reduces the EMI generated by an SX clocked at 50 MHz. Even a double-sided board with as many ground planes as possible on both sides helps reducing EMI, but a single sided pcb will end up in a nice transmitter with strong harmonics up to 200 MHz and even above.
The filter cap (typically 100 nF) connected between the SX supply pins does not really filter out those signals because even when you use a low inductance ceramic capactior, its leads are long enough to build an inductance, reducing the capacitor's filter effect at such high frequencies.
Greetings from Germany,
G
yes, you are right, I also could only find one jumper but a lot of resistors that can act as "jumpers" as well, i.e. act as a bridge over say 5 to 10 pcb traces.
In addition, the eight RB pins go "straight" through to the D-SUB connectors which makes the layout easier, and the four RA pins are not connected at all.
I better correct my statement that I doubt it is possible to design a one sided PCB for the SX 28 without jumpers, and better say that it might be impossible, depending on the complexity of the design, and what external components are to be connected to the SX 28.
Nevertheless, my major concern when preferring double sided, or even four-layer PCBs is the reduction of EMI produced by the SX. For a hobby application, this may not be too important but when you make designs for commercial applications this becomes an important issue. Without a carefully designed PCB, the system would hardly pass any EMI tests.
G
Hopefully, I will have to people to do the EMI tests, and find a solution to any problem. But thats not relevant at the moment, since I can't afford to even think "commercial application". Never the less, thank you for pointing that out - since it (and electrostatics) might actually explain why my SX responds to a button, even before i press it.
About the 0ohm resistor, I can only say Clever! Now why didn't I think of that - oh yes, cause I'm not as pro as I would like to be.
Forest
Thank you, I'll take a look at that, as soon as I've had something to eat. [noparse]:)[/noparse]
(I'm starting to get VERY interested in the EMI subject)
I plugged the frequencies into here: http://www.csgnetwork.com/freqwavelengthcalc.html·and the 1/4 wave for 50MHz is just shy of 5 feet, not a problem. But there are harmonics 2*f, 3*f etc which are also produced and a wrong trace length can act like a resonator for that harmonic wreaking havoc on your EMI numbers and can even cause problems within your circuit. I don't feel like going into an explaination of this because microwave transistor design was the one course in grad school I really struggled with, and it brings up really bad memories of weeks of little to no sleep and still bombing the exam
Paul
I don't mean to sound disrespectfull. The subject has cought my attention, and it seems to be a source of both bugs and hardwarefailure, but at the same time the main reason why I can control a model plane, while stading on the ground, with nothing but a pack of batteries and neatly wired transistors in my hand.
Is there any simple way to secure hobby projects from EMI? Would a wider trace reduce EMI? Does it even matter when I'm operating my SX at 50mHz but all other hardware on (up to) around 20kHz?
If it's too huge a subject, I'll just go ask google - I'll probably do that anyway, atleast sometime soon.
Please currect me if I'm wrong, but it seems you imply that long thin traces emit more EMI than... ? Short bold traces? I don't know if thats what you ment, I'm just trying to figure out what measures I have to take, to avoid building an EMI emitter, instead of a (sometimes) usefull application [noparse];)[/noparse]
Also, would it actually helt to have ground traces all around the PCB and when posible connect the unused PCB space for large grounded areas?
Several posts ago you asked about EMI references.· Have you seen Dave Van Horn's EMI info (http://dvanhorn.org/Emi/Index.php)?· His strong opinions seem to have been molded in the crucible of experience.
He would probably also answer a direct question about good EMI references.
HTH,
Daniel
I guess the answer to all my questions summs up to somethink like; avoid looping traces at all costs. Minimize the distance current has to flow and test the application next to an FM radio to get an rough indication of the emitted EMI.
With the right components and the right calibration, would it work for hobby-scale projects?
Post Edited (Paul Baker) : 1/13/2005 6:27:51 AM GMT
Cheers!
