Is the search function drain dead? — Parallax Forums
Jim McCorisonJim McCorison Posts: 359
edited 2005-06-15 05:31 in General Discussion
I have tried over and over to search for posts which I know are there, but the search doesn't find them. For instance, a search for "cold heat" or "cold, heat" in all forums for any dates yields no hits. And yet, there are at least two posts that I know of that include these terms:
www.parallax.com/detail.asp?product_id=28152
http://forums.parallax.com/showthread.php?p=516557
For that matter, a search for "cold" doesn't even yield the above posts!
If anybody can shed some light on how to use the search tool with more than one search term, I'd really appreciate it.
Jim
  • Jim EwaldJim Ewald Posts: 733
    edited 2005-01-09 18:12
    Jim, the search engine is on life support at the moment. I am testing an update to the seach engine that should produce much better results. The current system does a search based upon hash values. Nice idea, but it misses a lot of potential hits if you use the defaults. You do get better results if you select the 'Any words or phrases' search option. It does find at least three posts that reference 'cold'.
    Jim
    Parallax IT Dept.
  • Jim McCorisonJim McCorison Posts: 359
    edited 2005-01-09 18:28
    Using 'any' does find three hits. Althogh none of them are the links referenced in my inial post.
    I shall anxiously await the new search engine. Is there any kind of timeframe? Will you announce it in either this, or the Announcements forum if and when it is installed?
    Thanks much,
    Jim
    edited 2005-01-09 18:37
    When I search for 'cold' now, the engine only returns 2 hits. That certainly qualifies the engine for life support. The updates to the search engine should be posted in the next few days if the tests go well. I will post an announcement in the Announcements forum when the patches are deployed.
    The weather is clearing out here in soggy California. Time to ride.
    Jim
    Parallax IT Dept.
    edited 2005-01-09 19:54
    Jim said...
    Have fun. Down here in Chula Vista, in "sunny" Southern California, it's still solid gray and raining. But at least it's not blowing 20 knots like earlier.
  • MacGeek117MacGeek117 Posts: 747
    edited 2005-01-12 02:20
    I'm having trouble finding the motor driver circuit for the L293D chip, if anyone can
    help.
    bugg
    So many projects, so little time.
  • OrionOrion Posts: 236
    edited 2005-02-25 02:53
    How is this going...
    Seems like the search is still brain dead
    edited 2005-02-25 05:56
    I am experiencing similar problems...
    For example, try doing a search for "magic smoke" with "Any Date" to find my post...
    http://forums.parallax.com/showthread.php?p=525532
    ...nada
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    edited 2005-05-06 23:42
    Well the search seems to have a heart beat, you just need to hit search twice. The first time will give nothing, the second will give back a fist full of results.
  • RickBRickB Posts: 395
    Nope, clicking submit 2,3, 4, or 5 time still returns zero results for words I verified before searching, Search is STILL brain dead. Not even a heart beat.
    Rick
