scenix 28 in pcb123 parts library?
Does anyone know of a download for a scenix 28 part or a pic 16c57 for the PCB123 parts / schematic library? It seems this would be a common need. There must be something similar for Eagle. I am still using version 1 of PCB123 but may get to version 2 soon.
Jon Williams
Dallas, TX· USA
The advantages with this approach are that you can use proprietary designations for key components if you don't want others to simply copy and populate your board.
Actually, the correct design is your responsiblity, so they just care that you provide files that make manufacture doable. They do provide proto-typical packages to work from.
And once you have the SX-28 in there, it will save time in the future.
G. Herzog in Taiwan
ftp://ftp.cadsoft.de/pub/userfiles/libraries/scenix4.lbr
ftp://ftp.cadsoft.de/pub/userfiles/libraries/ubicom.lbr
ftp://ftp.cadsoft.de/pub/userfiles/libraries/ubicom_v2.lbr
Greetings from Germany,
G
