Producing Boards.
I'm using the LM34 in my company to measure room temperatures, and need to make a circuit board in order to mount. Something the size of a single gang box. What I am wondering whats the best way to make a circuit board. I see in IEEE magazine companies advertising services, such as www.PCB4u.com. I remeber using etching in college to make boards, but they always ended up needing more soldering than it was worth. Anyone have any suggestions ? I need to keep unit cost low. Thanks in advance.
Either a wire wrap board (perforated hole but no copper) or a project board (has copper traces or pads and must be "solder wired").
You could use a couple of IC sockets and plug your LM34 in to that (if you expect to change it).
I'd guess you might have a couple of caps on the board too....
To note, there is a thread on this in the SANDBOX.
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
