USB Re-Connection Error
SgtBFGunner
To test a program after uploading it to the BS2, I unplug the USB cable from the BOE. When I plug the USB back into the BOE for another upload from the editor, I get an error that "No BASIC Stamps Found." I close the editor and·get a couple Send Error to Microsoft boxes that pop up. I open the editor again and all is fine until going to disconnect and reconnect again after a trial run.
I have searched these forums but found no info... any ideas?·
· Gary
· Gary
What version of Windows are you using?· In any case, make sure to remove the drivers and reinstall them again.· Here is a link for the drivers:· http://www.parallax.com/detail.asp?product_id=28850·.· Make sure to scroll down and you'll see the drivers.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Jon Williams
Dallas Office
I downloaded "the latest" from http://www.ftdichip.com/Drivers/FT2232CDrivers.htm#VCP·, which they claim are ver. 1.0.3 dated 5th May 2004. I installed these and the .INF's say they are version 1.00.00, dated 03/12/2004. These did not work. Couldn't communicate the the USB or BS2 at all.
Went to the Parallax CD where I found the 1.0.2151.0 2/4/2004 drivers and they work like a charm.
So, for me (and maybe others), 1.0.2154.0 BAD, 1.2.2151.0 GOOD.
Thanks for the help!···
your VCP driver seem incorrect, it's used for FT2232 not FT232BM
you need to uninstall driver by call FTDIUNIN.EXE on folder and re-install correct VCP again
current driver on FTDI web is 1.00.2154
http://www.ftdichip.com/Drivers/FT232-FT245Drivers.htm
Try this
It brings me back to my original drivers·1.00.2154. Turns out the 1.0.2151.0 would just lock up eventually anyway.
Not sure why the editor's communication with the stamp·locks up after unplugging for a while.
eyeWyre's editor has no problem with all the plugging and unplugging...
-Gary
