BOEBOT cmucam to PC monitor
Hi, i have bought a boebot cmucam a month ago and i found that i have difficulties on tracking the color and the size of the image, so i would like to hook up the boebot cmucam to my pc to see the image. I knew that i will void the warrenty of the cam, but does anyone know what kind of chip i need to put on the boebot cam in order to connect boebot to PC serial port. Do·i need to add everything left from the original cmucam or just the MAX chip and some capacitor? is there any instructor i can follow?
thanks so much
thanks so much
RoboEye does exactly what you requested: http://www.parallax.com/detail.asp?product_id=30008·- not sure if you can modify a CMU cam to get the image on a PC.
Don't know what type of graph you could use....but that's all you could do with this.
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
