microphone (or pressure sensor) to BS2sx
Hi,
I'm trying to hook up some sort of pressure sensor to a stamp that will detect when I tap it with my hand, and that can send a different signal depending on how hard I hit it (I'm trying to make a drum pad).
I thought of using a microphone but I can't get the basic stamp to see anything. Does anybody know how to hook up a microphone to a BS2sx to get any numerical results?
Also, if the mics aren't a good idea, does anybody know what I can use as a pressure sensor that would be cheap and have (almost) no delay, and how I would connect this thing to a stamp?
Thanks for the help,
-Elie
-Elie
http://www.paia.com/midibrn.htm#thumdrum
and also published in an old issue of Radio Electronics, back when it was a solo publication. Paia also has a note on the sensors they use:
http://www.paia.com/drumsens.htm
Doing realtime force sensing is a little tricky, because you'll need to constantly monitor the voltage from the pads, probably with a multichannel ADC (analog to digital converter). I bet with a tight sampling loop you could make it work pretty well. You'll need to SHIFTIN() the apropriate data from the ADC and look for a maximum value, and then process that value into whatever you want it to do.
-dave
This is not a sig. This is a duck. Quack.
Ken
www.speechchips.com
www.msiusa.com/piezo/
Digikey carries some of the pickup films. A good strong tap can be picked up by the Stamp with no additional electronics other than the film itself.
Tracy Allen
www.emesystems.com
RadRay
