Useful application for the lowly old Stamp1-D — Parallax Forums
Robert SmitheRobert Smithe Posts: 2
edited 2004-11-13 05:59 in BASIC Stamp
Another good use for the Lowly old Stamp 1 D
This application uses two servos - the first to depress one of two buttons and the second servo
(modified for continuous rotation) to move a strip of paper thru a benchtop paper testing machine.
Once the newsprint sample is placed in the Parker Print Surf and the stamp is activated
the device tests 10 positions before the sample is manually turned over to repeat the sequence on
the second side. This allow more productive use of time as well as relief from a tedious task.
The only attachment to the original test equipment is the servo on front of machine. It is attached with with some packing foam with double sided masking tape on both sides.
Below are two pictures of Stamp1-D working happily on its own
as well as the simple but operational code for this application.
'stamp 1 d pin usage - switch input 4, test servo 1, move servo 0
symbol cont =  w0       ' W0 holds the count
symbol tests = b2 ' number of tests
symbol dwell = 15 ' reps for servo to move to and hold setpoint
STARTUP: output 0
         output 1
         input  4
         low 0
         low 1
     gosub center    ' center button pushing servo
loop: if pin4 = 0 then loop   ' loop until start switch pushed
      tests =1
test: for cont = 0 to dwell ' duration of test button down
      pulsout 1,125
      pause 20
      next cont
       gosub center
delay: for cont=1 to 7  ' wait for test to complete
       pause 1000
       next cont
back: tests=tests+1
      if tests>10 then avg
  move: for cont = 0 to 170 ' move sample between tests
      pulsout 0,120
      pause 20
      next cont
      if tests<11 then test
avg: pause 1000  ' wait 1 second before average button
     for cont = 0 to dwell   ' length of average button down
     pulsout 1,175  '  - terminates test series
     pause 20
     next cont
     gosub center
 goto startup
 center:  for cont = 0 to dwell     ' center test servo
     pulsout 1,150
     pause 20
     next cont
     return
end
Post Edited (Robert Smithe) : 11/28/2004 8:09:52 AM GMT
    Lowly? I think not! Lovely is a much more appropriate word for the BS1. tongue.gif
    Jon Williams
    Dallas Office
