Useful application for the lowly old Stamp1-D
Another good use for the Lowly old Stamp 1 D
This application uses two servos - the first to depress one of two buttons and the second servo
(modified for continuous rotation) to move a strip of paper thru a benchtop paper testing machine.
Once the newsprint sample is placed in the Parker Print Surf and the stamp is activated
the device tests 10 positions before the sample is manually turned over to repeat the sequence on
the second side. This allow more productive use of time as well as relief from a tedious task.
The only attachment to the original test equipment is the servo on front of machine. It is attached with with some packing foam with double sided masking tape on both sides.
Below are two pictures of Stamp1-D working happily on its own
as well as the simple but operational code for this application.
Post Edited (Robert Smithe) : 11/28/2004 8:09:52 AM GMT
'stamp 1 d pin usage - switch input 4, test servo 1, move servo 0
symbol cont = w0 ' W0 holds the count
symbol tests = b2 ' number of tests
symbol dwell = 15 ' reps for servo to move to and hold setpoint
STARTUP: output 0
output 1
input 4
low 0
low 1
gosub center ' center button pushing servo
loop: if pin4 = 0 then loop ' loop until start switch pushed
tests =1
test: for cont = 0 to dwell ' duration of test button down
pulsout 1,125
pause 20
next cont
gosub center
delay: for cont=1 to 7 ' wait for test to complete
pause 1000
next cont
back: tests=tests+1
if tests>10 then avg
move: for cont = 0 to 170 ' move sample between tests
pulsout 0,120
pause 20
next cont
if tests<11 then test
avg: pause 1000 ' wait 1 second before average button
for cont = 0 to dwell ' length of average button down
pulsout 1,175 ' - terminates test series
pause 20
next cont
gosub center
goto startup
center: for cont = 0 to dwell ' center test servo
pulsout 1,150
pause 20
next cont
return
end
Jon Williams
Dallas Office
