Help in Programming — Parallax Forums
Help in Programming
FardeenFardeen Posts: 9
edited 2004-11-12 20:52 in BASIC Stamp
I am currently working on a wireless vital sign monitor. My project includes taking heart, pressure and temperature signals and analysing them.
I accomplish this by taking the signals, filtering and amplifying them, converting them digitally and processing them in a microcontroller before transmitting them wireless and displaying them using Labview.
I am using a microconroller because I am using serial communications for Labview software instead of DAQ (due to budge issues).
My microcontroller code therefore (BS2) requires to take in 3 signals from 3 different ·A/D, decode them to binary, and then send them in an infinite loop in a·format
······················<Tab>Signal1<Tab>Signal2<Tab>Signal3.
I however suck at assembly language and inspite of refering to so many different sources and sites, I am still having a hard time accomplishing this.
Can anybody help me please???
jumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gif
    edited 2004-11-08 21:39
    Do yo want your pogram to run on the BASIC Stamp II? If yes, you will use PBASIC, not assembly.
    What A/D convertors are you using? We have lots of example code for differnt converters.
    Jon Williams
    Dallas Office
  • FardeenFardeen Posts: 9
    edited 2004-11-09 17:22
    I am using 8 bit A/D ( ADC08832)
    I will appreciate any examples and help I can get.
    Thanks alot.
    edited 2004-11-10 14:23
    I don't have an ADC0832, but I did write the attached code for someone who does -- they said it worked for them.· As always, I suggest that you review the ADC0832 docs before running the code ... I'm human.
    Jon Williams
    Dallas Office
    edited 2004-11-12 19:55
    Hey Jon
    I have written the code for my project. I just want someone to look over it.
    My program is supposed to take 3 input signals from 8 bits A/D (AD08831) and process them·so as to output serially in the format
    ····································· <Tab>Signal1<Sab>Signal2<Cab>Signal3
    so that I can separate them on receivind end (Labview).
    Also, is there a way I could just take a signle input from A/D into my chip and serially display the outut on the basic stamp editor??
    I noticed the connections between the [url=mailto:BS@-IC]BS2-IC[/url]·and RS232 on the BS2 manual and just wanted to doublecheck before doing that so as not to blow up anything.
    edited 2004-11-12 19:59
    Sorry. I forgot to attach the file in the first message.
    edited 2004-11-12 20:09
    <Tab> has an ASCII value of 9, and is a defined constant in PBASIC.
    You should be able to do this: SEROUT pin, baud, [noparse][[/noparse]TAB, sensorValue]
    Jon Williams
    Dallas Office
    edited 2004-11-12 20:32
    Thanks for the response Jon.
    Can I just use a single line command as
    SEROUT pin, baud, 50, timeout, [noparse][[/noparse]TAB, sig1, CR, sig2, TAB, sig3]
    where timeout is a label
    Also, would the constants TAB, CR, and·TAB each be sent as 8 bits serially or?????
    I would be very thankful if you can overlook my code please.
    Thanks again
    Yes, you can do that; but note that there is no timeout parameter for SEROUT -- what you send gets sent. If you need to make sure that the receiver is ready then you'll have to use flow control. Our RS-232 AppMod shows how to do this (you'll also need a pin for the flow control input).
    Jon Williams
    Dallas Office
