DEBUG X runs program??? — Parallax Forums
GlimpGlimp Posts: 1
edited 2004-11-10 21:34 in BASIC Stamp
Why is it that my programs run properly only when I add the redundant statement "DEBUG X" somewhere in the program???
  • edited 2004-11-10 21:34
    Hello,
    Some new systems (Dells, Gateways, HP) laptops ·will allow you to program the stamp but will not let it run with the programming cable attached or only run when a debug command is in the code. This is a know problem and is being worked on. In the mean time the only fix is unplugging the cable or putting a debug command in the code.
    Are you running this on a laptop?
    Stephen Swanson
    Technical Support
    sswanson@parallax.com
