Hello,
Some new systems (Dells, Gateways, HP) laptops ·will allow you to program the stamp but will not let it run with the programming cable attached or only run when a debug command is in the code. This is a know problem and is being worked on. In the mean time the only fix is unplugging the cable or putting a debug command in the code.
Are you running this on a laptop?
Stephen Swanson
Technical Support
Parallax, Inc. sswanson@parallax.com
Stephen Swanson
Technical Support
