Calling MCP23016 pins
I have an MCP23016 with a lot of lines working.· I need to monotor the state of just of of the pins.· Can I write
if GP0.7·= 128 then do something?
12 of the pins on the chip could be in any state but I am only concerned about the state of GP0.7
Sid
Sid
Chris Savage
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
Jon Williams
Dallas Office
if GP0>=128 then dosomething.·
This statement is true only of GP0.7 is
high.· If it is NOT true, then GP0.7 must be low.
Sid
flags VAR Byte frGate VAR flags.BIT7 IsOpen CON 1 ... IF (frGate = IsOpen) THEN ' deal with open front gate ENDIFTo many this seems like a lot of work, but after 20 years of programming I can assure you that it saves the programmer time, and is immensely helpful when that same programmer wants to share his/her code with others.· It's also helpful when you change a circuit design as a couple changes in your definitions section is easier than hunting through a long listing for "magic numbers."
Jon Williams
Dallas Office
